Home » Modeling » Graphiti » Problems with respect to printers: Slow performance
Problems with respect to printers: Slow performance [message #716807] Thu, 18 August 2011 14:03 Go to next message
Ivar Refsdal is currently offline Ivar RefsdalFriend
Hello everybody!
First off: Thanks to the developers for a absolutely very interesting
project. I'm quite thrilled about it.
However, I ran into some small problems.
When selecting between the canvas and nodes/shapes, the performance
was very slow.
Two or three times the following exception occurred:
> java.lang.RuntimeException: WARNING: Prevented recursive attempt to activate part org.eclipse.ui.navigator.ProjectExplorer while still in the middle of activating part org.eclipse.ui.views.ProblemView
The full stack trace is available here: http://pastebin.com/dumpGvE7
Anyhow, the problem turned out to be the following:
> at org.eclipse.swt.widgets.Display.eventProc(Display.java:1238)
> at org.eclipse.swt.internal.gtk.OS._gtk_enumerate_printers(Native Method)
> at org.eclipse.swt.internal.gtk.OS.gtk_enumerate_printers(OS.java:9091)
> at org.eclipse.swt.printing.Printer.getPrinterList(Printer.java:91)
> at org.eclipse.gef.ui.actions.PrintAction.calculateEnabled(PrintAction.java:45)
> at org.eclipse.graphiti.ui.internal.action.PrintGraphicalViewerAction.calculateEnabled(PrintGraphicalViewerAction.java:98)
I suppose the real problem lies within SWT somewhere or this particular
printer setup, but calculateEnabled() gets called very often, for
example every time when you select the canvas or a node, so caching this
would effectively fix the problem.
With making calculateEnabled() return false, the slow performance
disappeared and everything ran very smooth.
Note: There's quite a few printers available (20-30) at this uni, so the
setup is somewhat special. If one chooses "print" from Eclipse,
the dialog where one chooses the printer is also very slow,
but as far as I know this hasn't affected any of the plugins notably,
and also it doesn't crash.
Also an exception occurs if one chooses:
"File" -> "Print" -> "Change printer" -> "Cancel"
See stacktrace here: http://pastebin.com/xjYhm9ep
Should I file a bug report for this or something similar?
Ivar Refsdal
Re: Problems with respect to printers: Slow performance [message #717082 is a reply to message #716807] Fri, 19 August 2011 08:50 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
Ivar,
thanks for pointing out! In Windows this doesn't seen to be an issue, but
other OS seem to behave differently.
Please open a Bugzilla to track this. What is the OS you are working on?
Michael
"Ivar Refsdal" schrieb im Newsbeitrag news:j2j5f6$8i0$1@news.eclipse.org...
Hello everybody!
was very slow.
> at
> at
Ivar Refsdal
Re: Problems with respect to printers: Slow performance [message #717870 is a reply to message #717082] Mon, 22 August 2011 15:06 Go to previous message
Hi Michael,
thanks for you reply!
A bug report has been submitted:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=355401
The OS is:
> $ cat /proc/version
> Linux version 2.6.18-274.el5 (mockbuild@x86-002.build.bos.redhat.com) (gcc
> version 4.1.2 20080704 (Red Hat 4.1.2-51)) #1 SMP Fri Jul 8 17:36:59 EDT 2011
Best,
Ivar
Michael Wenz wrote, on 08/19/2011 10:50 AM:
> Ivar,
> but other OS seem to behave differently.
> Michael
> Hello everybody!
> was very slow.
>> at
>> at
> Best regards,
> Ivar Refsdal
Previous Topic:IGaService.creatFont() ?
Next Topic:Error: Graphiti 0.8.0 and Eclipse BPMN2
Current Time: Sat May 26 04:27:42 GMT 2018
Powered by FUDForum. Page generated in 0.01859 seconds
