Home » Eclipse Projects » BIRT » Calculate Cumulative value in Chart(Calculate Cumulative value in Chart)
Calculate Cumulative value in Chart [message #716731] Thu, 18 August 2011 09:08 Go to next message
jeyinul  is currently offline jeyinul Friend
Member
Hi Jason,
How to calculate cumulative value( i.e running sum) for chart.
Please explain.
Jeyinul.
Re: Calculate Cumulative value in Chart [message #716825 is a reply to message #716731] Thu, 18 August 2011 14:16 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
On the y-axis there is an aggregation function selector on the second
tab of the chart wizard. You should be able to set the function to
running sum.
Jason
On 8/18/2011 5:08 AM, jeyinul wrote:
> Hi Jason,
> Please explain.
> Jeyinul.
Re: Calculate Cumulative value in Chart [message #717121 is a reply to message #716825] Fri, 19 August 2011 11:14 Go to previous messageGo to next message
Member
Hi Jason,
Running sum function is not working. i am getting the same report like sum.
Re: Calculate Cumulative value in Chart [message #717180 is a reply to message #717121] Fri, 19 August 2011 14:27 Go to previous message
Can you create a report using the sample db that shows the issue?
Jason
On 8/19/2011 7:14 AM, jeyinul wrote:
> Hi Jason,
Re: Calculate Cumulative value in Chart [message #717183 is a reply to message #717121] Fri, 19 August 2011 14:27 Go to previous message
Jason
> Hi Jason,
Previous Topic:MONTH IS NOT IN PROPER ORDER IN CHART
Next Topic:BIRT reports driven from SVN as a datasource
Current Time: Fri Jan 19 17:53:55 GMT 2018
Powered by FUDForum. Page generated in 0.01484 seconds
