Home » Modeling » EMF » [EMF.core] EObjectValidator does not support multiple inheritance validation
[EMF.core] EObjectValidator does not support multiple inheritance validation [message #716712] Thu, 18 August 2011 07:22 Go to next message
Ed Willink is currently offline Ed WillinkFriend
In
EObjectValidator.validate(EClass eClass, EObject eObject,
DiagnosticChain diagnostics, Map<Object, Object> context)
the recursion (for non-EcorePackage) to superclass is via
validate(eSuperTypes.get(0), eObject, diagnostics,
context);
rather than a loop over all eSuperTypes, so constraints inherited from a
second supertype are ignored.
Is this deliberate or an oversight? It's certainly a convenient way of
avoiding double validation of a constraint
inherited from more than one superclass.
Ed Willink
Re: [EMF.core] EObjectValidator does not support multiple inheritance validation [message #716887 is a reply to message #716712] Thu, 18 August 2011 17:15 Go to previous messageGo to next message
Ed,
I suppose, it's the best we can do when an appropriately dispatching
generated validator isn't produced. You can think of it as similar to
not being able to extend two different generated classes dynamically.
However, Kenn added support for delegates later in the evolution, and
it's a bit more problematic from that angle, i.e., in the fully dynamic
case, you'd hope all the constraints from all the supers would be
considered. I'll ask Kenn to comment...
On 18/08/2011 12:22 AM, Ed Willink wrote:
> Hi
> In
> context);
> a second supertype are ignored.
> Regards
> Ed Willink
Re: [EMF.core] EObjectValidator does not support multiple inheritance validation [message #717024 is a reply to message #716887] Fri, 19 August 2011 05:20 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=355184 raised to better
persist comments.
Ed Willink
On 18/08/2011 18:15, Ed Merks wrote:
> Ed,
> dynamic case, you'd hope all the constraints from all the supers would
> be considered. I'll ask Kenn to comment...
>> Hi
>> In
>> context);
>> from a second supertype are ignored.
>> of avoiding double validation of a constraint
>> Regards
>> Ed Willink
Previous Topic:Set attribute of EMap, EEList
Next Topic:[Resolved] Import emf model in another
Current Time: Tue May 22 02:49:07 GMT 2018
Powered by FUDForum. Page generated in 0.01768 seconds
