Home » Eclipse Projects » EGit / JGit » [Https] Can't save the password.
[Https] Can't save the password. [message #716393] Wed, 17 August 2011 09:32 Go to next message
Dollyn Sun is currently offline Dollyn SunFriend
Member
I'm using EGit in the indigo build.
When I do the operation 'clone' or 'push' or 'config push' or anywhere i need to config the remote uri info, if I check the 'Store in Secure Store' check box in the dialog, there will always be a error at the end of the operation.
The error log:
org.eclipse.equinox.security.storage.StorageException: No password provided.
	at org.eclipse.equinox.internal.security.storage.SecurePreferencesRoot.getModulePassword(SecurePreferencesRoot.java:304)
	at org.eclipse.equinox.internal.security.storage.SecurePreferencesRoot.getPassword(SecurePreferencesRoot.java:224)
	at org.eclipse.equinox.internal.security.storage.SecurePreferences.put(SecurePreferences.java:224)
	at org.eclipse.equinox.internal.security.storage.SecurePreferencesWrapper.put(SecurePreferencesWrapper.java:110)
	at org.eclipse.egit.core.securestorage.EGitSecureStore.putCredentials(EGitSecureStore.java:58)
	at org.eclipse.egit.ui.internal.SecureStoreUtils.storeCredentials(SecureStoreUtils.java:36)
	at org.eclipse.egit.ui.internal.repository.SelectUriWizard.performFinish(SelectUriWizard.java:58)
	at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
	at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
	at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.egit.ui.internal.push.SimpleConfigurePushDialog$1.widgetSelected(SimpleConfigurePushDialog.java:278)
	at org.eclipse.egit.ui.internal.repository.tree.command.ConfigurePushCommand.execute(ConfigurePushCommand.java:39)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
	at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
	at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
	at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
	at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Dollyn
Re: [Https] Can't save the password. [message #716495 is a reply to message #716393] Wed, 17 August 2011 14:57 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
Please file a bug in Bugzilla and provide more details (EGit and platform version, operating system, steps to reproduce the problem).
Re: [Https] Can't save the password. [message #727110 is a reply to message #716495] Tue, 20 September 2011 12:35 Go to previous message
I hit the same problem and found that I had OS X Keystore Integration switched on in
"Preferences > General > Security > Secure Storage". Switching off the OS X keystore
integration fixed the problem. Also deleting the secure store and recreating a new one
worked also when OS X keystore integration is switched on. Maybe there is a way to corrupt
the secure store in terms of its integration to the operating system's keyring. It seems
not using the native keyring integration or recreating a fresh new secure store can
workaround this problem.
Previous Topic:How to do a "git pull origin subbranch:subbranch" in jgit?
Next Topic:EGIT plugin in eclipse.
Current Time: Mon Jun 18 02:20:21 GMT 2018
Powered by FUDForum. Page generated in 0.01544 seconds
