Home » Modeling » UML2 » changing values programmatically at UML model
changing values programmatically at UML model [message #716382] Wed, 17 August 2011 08:51 Go to next message
Atif Javed is currently offline Atif JavedFriend
Hello Friends,
I want to change some values at UML model programmatically. I am able to get values but don't have idea about how to change and update values at UML model. Any help is appreciated.
Atif/
Re: changing values programmatically at UML model [message #716478 is a reply to message #716382] Wed, 17 August 2011 14:06 Go to previous messageGo to next message
Call the setX(value) methods or use getX().add(value) methods if it's
multi-valued.
On 17/08/2011 1:51 AM, Muhammad Atif Javed wrote:
> Hello Friends,
> Atif/
Re: changing values programmatically at UML model [message #716713 is a reply to message #716382] Thu, 18 August 2011 08:00 Go to previous message
Vlad Varnica is currently offline Vlad VarnicaFriend
You can change value either like Ed says using java code or if you are not an experienced Eclipse developer then you can open the .uml file with the UML Editor. You can see the structure of the model and if you click on a model element and open the property tab you would be able to change value manually.
Hope this help.
Previous Topic:How to draw diagrams in Indigo?
Next Topic:Stereotypes are not applied to exported MD-xmi files
Current Time: Sun May 20 23:27:55 GMT 2018
Powered by FUDForum. Page generated in 0.01817 seconds
