Home » Newcomers » Newcomers » Change default size (width/height) of ToolTip (hover, popup, evaluator, inspector) in debug mode
Change default size (width/height) of ToolTip (hover, popup, evaluator, inspector) in debug mode [message #713915] Tue, 09 August 2011 11:20 Go to next message
Andrew  is currently offline Andrew Friend
When I mouse over variable in debug mode, tooltip always have small size. I have to always resizing manually.
Can I change default size (width and height) this tooltip (combined hover)?
[Updated on: Tue, 09 August 2011 13:26]
Report message to a moderator
Re: Change default size (width/height) of ToolTip (hover, popup, evaluator, inspector) in debug mode [message #736146 is a reply to message #713915] Thu, 13 October 2011 16:55 Go to previous messageGo to next message
Chris Stankevitz is currently offline Chris StankevitzFriend
Member
Andrew,
Did you figure this out? If so, please post the solution.
Thank you,
Chris
Re: Change default size (width/height) of ToolTip (hover, popup, evaluator, inspector) in debug mode [message #1013968 is a reply to message #713915] Sun, 24 February 2013 21:24 Go to previous message
J L is currently offline J LFriend
I'd also like to know if this is possible...
I'd like the hover popup to be bigger by default. The ideal would be that it remembers the size we give it!
Previous Topic:"Prompt for workplace on startup" always doesn't work
Next Topic:Outline-window in Juno
Current Time: Sat May 26 21:49:44 GMT 2018
Powered by FUDForum. Page generated in 0.02353 seconds
