Home » Language IDEs » Java Development Tools (JDT) » autocomplete not acting as I expect(control-space is not giving me options, I get a yellow background and red foreground intermittently )
autocomplete not acting as I expect [message #712145] Sun, 07 August 2011 03:41 Go to next message
Ralph Cook is currently offline Ralph CookFriend
I am using Eclipse Indigo, and programming a method that starts this way:
  public void display()
    JLabel label1 = new JLabel("one");
    JScrollPane scrollPane1 = new JScrollPane(label1);
    JLabel txtMessages = new JLabel("These are the times that fry men's soles.");
    JPanel bigCourtInfoPanel = new JPanel();
    bigCourtInfoPanel.setLayout(new BoxLayout(bigCourtInfoPanel, BoxLayout.Y_AXIS));
Right under the "JLabel txtMessages" line, I can type "txtMessages.", and I would expect an content assist with the methods available for the txtMessages variable. None appear. I would also expect content assist if I enter control-space, but none appear then either.
What I do get, intermittently, is a yellow background and red foreground highlight on the rest of the method. I don't know what that means.
1. What is the yellow/red highlighting?
2. How do I get my list of content-assist methods?
Re: autocomplete not acting as I expect [message #712647 is a reply to message #712145] Sun, 07 August 2011 14:33 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
> soles.");
> BoxLayout.Y_AXIS));
Have you added an import for JLabel? If not, then JLabel won't be able
to be resolved so it won't be possible to provide content assist.
Re: autocomplete not acting as I expect [message #713158 is a reply to message #712145] Mon, 08 August 2011 06:53 Go to previous message
Dani Megert is currently offline Dani MegertFriend
> men's soles.");
> BoxLayout.Y_AXIS));
> that means.
This normally appears to the right and means that that this text will be
replaced when inserting the proposal.
You should get it if you place the caret after the "textMessages." and
invoke Ctrl+Space. If that is not the case then please file a bug
against JDT Text
(https://bugs.eclipse.org/bugs/enter_bug.cgi?product=JDT;component=Text).
Dani
Previous Topic:swing app in intranet
Next Topic:Accessing Debugging Information
Current Time: Wed May 23 17:08:50 GMT 2018
Powered by FUDForum. Page generated in 0.01884 seconds
