Home » Language IDEs » C / C++ IDE (CDT) » Running shell scripts as external tools
Running shell scripts as external tools [message #74649] Wed, 02 July 2003 15:28 Go to next message
Originally posted by: tim.barrass.bris.ac.uk
Hi all,
I've just got started with Eclipse and the CDT plugin after using KDevelop
and Visual Studio- and am really happy with it so far :o)
I'd like to be able to run a shell script as an External tool. I create a
shell script, and make it executable, within my workspace.
I go to Run->External Tools->External Tools I set up a new Program, with
location
${workspace_loc:/Pool/run.sh}
working directory
${container_loc}
and no other configuration. When I try Run, it tells me
Exception occurred executing command line.
(Yep, it does run from the command line!). The script is:
#!/bin/bash
echo hello!
Any help gratefully received :o) Cheers,
Tim
Re: Running shell scripts as external tools [message #74667 is a reply to message #74649] Wed, 02 July 2003 15:38 Go to previous messageGo to next message
.. and I'm using platform 2.1.0 and CDT 1.1.0, ta.
Tim Barrass wrote:
> Hi all,
> location
> working directory
> ${container_loc}
> #!/bin/bash
> echo hello!
> Tim
Re: Running shell scripts as external tools [message #74684 is a reply to message #74649] Wed, 02 July 2003 15:57 Go to previous messageGo to next message
Originally posted by: burner.zclipse.org
> location
I believe the problem is that you can't call exec() on a shell script. You
have to specify the location to be /bin/sh and the argument to be
${work...
At least, that's what I do when I need to call a shell script...
mike
Re: Running shell scripts as external tools [message #74735 is a reply to message #74649] Wed, 02 July 2003 22:07 Go to previous messageGo to next message
Originally posted by: gcaglar.hotmail.com
You have to make the script executable, i.e., chmod +x a.sh
Gokhan
"Tim Barrass" <tim.barrass@bris.ac.uk> wrote in message
news:bdutnp$nsv$1@rogue.oti.com...
> Hi all,
> location
> working directory
> ${container_loc}
> #!/bin/bash
> echo hello!
> Tim
Re: Running shell scripts as external tools [message #74799 is a reply to message #74684] Thu, 03 July 2003 09:01 Go to previous messageGo to next message
Cheers Mike, that works fine for me now :o)
Tim
>>location
> ${work...
> mike
Re: Running shell scripts as external tools [message #74815 is a reply to message #74799] Thu, 03 July 2003 12:28 Go to previous message
The difference is doing:
/bin/sh a.sh
or having the permissions of a.sh set right and just saying
a.sh
you don't have to start your script with #! if you are doing the first
one...
Gokhan
<user@domain.invalid> wrote in message news:3F03F0D4.10504@domain.invalid...
> Cheers,
> Tim
> >>location
You
> > ${work...
> > mike
Previous Topic:Setting breakpoint before pressing Debug button in debugger tab
Next Topic:Outline textformating with blank before open brace
Current Time: Sun Feb 18 09:27:48 GMT 2018
Powered by FUDForum. Page generated in 0.01748 seconds
