Home » Modeling » TMF (Xtext) » UnsupportedOperationException: getEObjectURI
UnsupportedOperationException: getEObjectURI [message #707523] Mon, 01 August 2011 19:10 Go to next message
Rafael Angarita is currently offline Rafael AngaritaFriend
Member
I'm having problems doing code generation. I implemented the IXtextBuilderParticipant interface. A new java project containing the generated code is created.
If I do a full clean without generating the code, everything goes well. If I do a full clean with the code generation activated, the first time everything seems to go well, but if I do a second full clean, I get the exception:
java.lang.UnsupportedOperationException: getEObjectURI
	at org.eclipse.xtext.common.types.ui.notification.NameBasedEObjectDescription.getEObjectURI(NameBasedEObjectDescription.java:45)
	at altagracia.builder.XtextAltagraciaBuilderParticipant.build(XtextAltagraciaBuilderParticipant.java:106)
	at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
	at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:160)
	at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:182)
	at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:85)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
	at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
	at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
	at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:513)
	at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:422)
	at org.eclipse.ui.actions.GlobalBuildAction$1.run(GlobalBuildAction.java:180)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
and the building process crash, leaving the xtetx project full of errors and unresolved references.
This is the fragment of code where the exception occurs:
 for (IResourceDescription.Delta delta : context.getDeltas()) {
    if (delta.getNew() != null){
	//URI uri = getObjectUrl(delta.getNew());
	Iterable<IEObjectDescription> descNew = delta.getNew().getExportedObjects();
	for (IEObjectDescription desc : descNew) {
                //the next line causes the exception
		newFile(context.getResourceSet().getEObject( desc.getEObjectURI(), true));
   monitor.worked(1);
Do you have any idea of what is going wrong here or how to debug this problem?
Thank you very much for your help.
Re: UnsupportedOperationException: getEObjectURI [message #707537 is a reply to message #707523] Mon, 01 August 2011 19:38 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
i guess your way is not the intended one. have a look at JavaProjectBasedBuilderParticipant
Resource resource = context.getResourceSet().getResource(delta.getUri(), true);
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: UnsupportedOperationException: getEObjectURI [message #707583 is a reply to message #707537] Mon, 01 August 2011 20:49 Go to previous messageGo to next message
Member
Hi Christian,
I had a look at it and I'm wondering JavaProjectBasedBuilderParticipant is what I need. I found this:
final IProject builtProject = context.getBuiltProject();
IJavaProject javaProject = JavaCore.create(builtProject);
if (!javaProject.exists())
    return;
The project where the user write code with my DSL is not a Java project, but the generated project during the clean is.
Should I use JavaProjectBasedBuilderParticipant? If you have any example I could look at, I'd really appreciate it.
Thank you very much!
Re: UnsupportedOperationException: getEObjectURI [message #707586 is a reply to message #707583] Mon, 01 August 2011 20:56 Go to previous messageGo to next message
Hi, i just pointed at it As a source of Inspiration.
Re: UnsupportedOperationException: getEObjectURI [message #707646 is a reply to message #707523] Mon, 01 August 2011 22:32 Go to previous message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Rafael,
please make sure that the file extension of the resource(delta) that you
process is matching your language. The NameBasedEObjectDescription will
most likely point to something with an URI similar to
"java:/Objects/com.foo.bar.Something". I'd assume you are more
interested in "platform:/resource/yourproject/somet/path/file.yourdsl"
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
On 01.08.11 21:10, Rafael Angarita wrote:
> Hello,
> exception:
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> true)); }
> monitor.worked(1);
> problem?
Previous Topic:Content Assist error
Next Topic:extend xbase with a binary literal
Current Time: Thu May 24 02:39:03 GMT 2018
Powered by FUDForum. Page generated in 0.01616 seconds
