how to get ALL element declarations ? [message #73198] |
Wed, 24 October 2007 10:28 |
Originally posted by: t.agnoloni.gmail.com
how can I get ALL and not only top-level element declarations from a
schema ?
Using XSDSchema.getElementDeclarations()
for the example below
only returns the element named "sizes"
and not the ones defined inside the following complex type definitions
Thanks.
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xs:element name="sizes" type="SizesType"/>
<xs:complexType name="SizesType">
<xs:choice maxOccurs="unbounded">
<xs:element name="dressSize" type="DressSizeType"/>
<xs:element name="mediumDressSize" type="MediumDressSizeType"/>
</xs:choice>
</xs:complexType>
<xs:simpleType name="DressSizeType">
<xs:restriction base="xs:integer">
<xs:minInclusive value="2"/>
<xs:maxInclusive value="18"/>
<xs:pattern value="\d{1,2}"/>
</xs:restriction>
</xs:simpleType>
<xs:simpleType name="MediumDressSizeType">
<xs:restriction base="DressSizeType">
<xs:minInclusive value="8"/>
<xs:maxInclusive value="12"/>
</xs:restriction>
</xs:simpleType>
</xs:schema>
Re: how to get ALL element declarations ? [message #73215 is a reply to message #73198] |
Wed, 24 October 2007 12:05 |
Tomasso,
You'll need to walk the deep structure of all element declarations
(including their anonymous complex types), all complex type definitions
(in particular their particle contents and of course recursively the
anonymous complex types of the element declarations), and all model
group definitions (in particular, the model group's contents).
Tommaso wrote:
> schema ?
> Thanks.
> </xs:choice>
> </xs:complexType>
> </xs:restriction>
> </xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:schema>
Re: how to get ALL element declarations ? [message #73529 is a reply to message #73215] |
Fri, 14 December 2007 17:39 |
Ok, thanks. It works.
However I have a new question.
How can I discard top level elements (already gathered with
schema.getElementDeclarations() ) when looking for non top level elements
navigating into i.e. complexTypeDefinitions ?
I would use the condition
!elemDecl.isElementDeclarationReference()
to collect the not referred elements
but the ref="topLevelElement" attribute seems to be already resolved when
I get into a term of type XSDElementDeclaration in a complexTypeDefinition.
Any hint?
I'm using the following code. Thank you very much for your help.
private void getNonTopLevelElements(XSDTypeDefinition typedef){
if (typedef instanceof XSDSimpleTypeDefinition){
System.err.println("SIMPLE TYPE cannot contain element");
else if (typedef instanceof XSDComplexTypeDefinition){
if(typedef.getComplexType()!=null){
XSDComplexTypeDefinitionImpl typedefimpl=
(XSDComplexTypeDefinitionImpl)typedef;
System.err.println("---------> ANALYZING TYPEDEF
"+typedefimpl.getName());
if
(typedefimpl.getContentTypeCategory()==XSDContentTypeCategor y.ELEMENT_ONLY_LITERAL
typedefimpl.getContentTypeCategory()==XSDContentTypeCategory .MIXED_LITERAL){
XSDTerm term =
((XSDParticleImpl)typedefimpl.getContentType()).getTerm();
getNonTopLevelElementForTerm(term);
private void getNonTopLevelElementForTerm(XSDTerm term){
if(term instanceof XSDElementDeclaration){ // ELEMENT
XSDElementDeclaration elemDecl=(XSDElementDeclaration)term;
if(!elemDecl.isElementDeclarationReference()){
allElements.add(elemDecl);
System.err.println("found NON TOP LEVEL "+elemDecl.getQName()+" ref=
"+elemDecl.isElementDeclarationReference());
else
System.err.println("found REFERRED "+elemDecl.getQName());
else if(term instanceof XSDModelGroup){ // CHOICE,
SEQUENCE
XSDModelGroup modelGroup=(XSDModelGroup)term;
List list = modelGroup.getParticles();
for (Iterator i = list.iterator();i.hasNext();){
XSDParticleImpl particle=(XSDParticleImpl) i.next();
getNonTopLevelElementForTerm(particle.getTerm());
}else if(term instanceof XSDWildcard){
System.out.println("XSDWildcard");
}else{
System.out.println("XSDTermIMpl");
Re: how to get ALL element declarations ? [message #73547 is a reply to message #73529] |
Fri, 14 December 2007 19:10 |
Tommaso,
Comments below.
> elements navigating into i.e. complexTypeDefinitions ?
> when I get into a term of type XSDElementDeclaration in a
In the code below I see that you are using things like getTerm which
does indeed resolve the reference so you'll already be looking at the
global element declaration directly. You can use
XSDFeature.getScope() or even XSDConcreteComponent.getContainer to see
if the element declaration is contained directly by an XSDSchema as
opposed to being contained by a particle in a complex type or model
group definition.
> Any hint?
> element");
> TYPEDEF "+typedefimpl.getName());
> if
> XSDTerm term =
> if(term instanceof
> "+elemDecl.getQName()+" ref= "+elemDecl.isElementDeclarationReference());
> else
> SEQUENCE XSDModelGroup
> }else{
Re: how to get ALL element declarations ? [message #602676 is a reply to message #73198] |
Ed Merks Messages: 33140 Registered: July 2009 |
Tomasso,
Tommaso wrote:
> schema ?
> Thanks.
> </xs:choice>
> </xs:complexType>
> </xs:restriction>
> </xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:schema>
Ed Merks
Re: how to get ALL element declarations ? [message #602781 is a reply to message #73529] |
Tommaso,
Comments below.
group definition.
> Any hint?
> element");
> if
> XSDTerm term =
> if(term instanceof
> else
> }else{
Ed Merks
FUDForum. Page generated in 0.03859 seconds
