Home » Modeling » TMF (Xtext) » scope and qualified name(How to implement local scope?)
scope and qualified name [message #704360] Thu, 28 July 2011 14:34 Go to next message
alex.ren2006 is currently offline alex.ren2006Friend
Member
I am currently building an IDE for ATS (www.ats-lang.org). I got into some problems dealing with scope. The documentation is a little bit too advanced for me to understand this topic. The following is some of my guess. Please correct me if I am wrong. For clarity, I use the following sample grammar for language "Myscope".
grammar org.xtext.example.mydsl.MyScope with org.eclipse.xtext.common.Terminals
generate myScope "http://www.xtext.org/example/mydsl/MyScope"
Program:
	body
body: {body}
	(mscope+=scope
	| mdef+=def
scope: {scope}'scope' mbody=body 'end';
def: name=ID '=' (mint=INT | mval=[def | ID]);
The corresponding source code would be something like this
x = 3
scope
  x = 4
end
z = x
The "x" in "z = x" refers to the "x" in "x = 4" which is actually within the scope and this is not what I want.
Once I modify the grammar into the following (simply by add name to scope)
Program:
	body
body: {body}
	(mscope+=scope
	| mdef+=def
scope: {scope}'scope' name=ID mbody=body 'end';
The cross-reference works correctly. So I think the problem is related to the concept "qualified name". The solution coming up in my mind is to create my own QualifiedNameProvider which extends DefaultDeclarativeQualifiedNameProvider so that element inside scope can have a longer qualified name. Am I on the right track?
Continue on this idea, since the "scope" in my language really doesn't have a name, what's the best solution for assignning names to element inside the scope? Any suggestion is highly appreciated. Thanks a lot.
Re: scope and qualified name [message #704380 is a reply to message #704360] Thu, 28 July 2011 14:52 Go to previous message
Christian Dietrich is currently online Christian DietrichFriend
this is what a QualifiedNameProvider is for
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @chrdietrich
Blog : christiandietrich.wordpress.com
Previous Topic:Scoping & "Cyclic resolution of lazy links" error
Next Topic:Invalid XML character (Unicode: 0x0) exception with xmlVersion 1.1 in Xtext2
Current Time: Wed Jan 24 10:07:27 GMT 2018
Powered by FUDForum. Page generated in 0.01536 seconds
