Home » Language IDEs » Java Development Tools (JDT) » Eclipse Graphic Xml Editor Not showing Scroll view
Eclipse Graphic Xml Editor Not showing Scroll view [message #702169] Tue, 26 July 2011 03:56 Go to next message
Reg  is currently offline Reg Friend
Im using eclipse EE IDE the latest version.
As you can see I cant view the whole screen.
How can I fix this???
index.php/fa/3475/0/
  • Attachment: KwM7L.png
    (Size: 338.99KB, Downloaded 954 times)
[Updated on: Tue, 26 July 2011 03:57]
Report message to a moderator
Re: Eclipse Graphic Xml Editor Not showing Scroll view [message #714586 is a reply to message #702169] Thu, 11 August 2011 00:35 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
I can also see that that is the Android Visual Layout editor, not the
XML Editor provided from eclipse.org.
http://tools.android.com/feedback
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Eclipse Graphic Xml Editor Not showing Scroll view [message #719674 is a reply to message #714586] Sun, 28 August 2011 10:31 Go to previous messageGo to next message
Scotty Huff is currently offline Scotty HuffFriend
Having the same issue. I'm using the same editor as above, which is the XML editor provided within Eclipse.
There must be a way to see the entire scroll view while editing. Any insight would be greatly appreciated.
Re: Eclipse Graphic Xml Editor Not showing Scroll view [message #719731 is a reply to message #719674] Sun, 28 August 2011 16:45 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
This is not an editor provided by Eclipse. A previous post seems to
indicate that this has something to do with Android. Android is not
Eclipse. It runs on top of Eclipse. You will get more help if you post
in the Android forums.
Re: Eclipse Graphic Xml Editor Not showing Scroll view [message #719936 is a reply to message #719731] Mon, 29 August 2011 14:10 Go to previous message
Sorry if this was in the wrong forum. I'm a noob, however...
This doesn't seem like a problem specific to Android, rather the way the graphical
Editor is representing the code. It would be nice, when creating a scroll view, if there
Were some way to actually scroll the content in the editor without having to temporarily
change the resolution of the device your designing for.
But if this belongs in a different forum, I'll look there. Thanks!
Previous Topic:Maven + Junit+eclipse+dependency order
Next Topic:Stepping into decompiled code without debug
Current Time: Mon Jun 18 06:24:05 GMT 2018
Powered by FUDForum. Page generated in 0.01588 seconds
