New datasource running on RCP [message #72002] |
Sun, 04 September 2005 23:40 |
Originally posted by: calltl.hotmail.com
I've just started using BIRT for my RCP project. All I want to do is to
export my internal application data to a BIRT report. Firstly I create a
new data source by using an extension point
"org.eclipse.birt.data.oda.dataSource". I try to follow the driver code for
flat file data source, and my data source works all the way to "Preview
Results" in "Edit Data Set" dialog. The problem arise when I preview my
design. It gives me an undesirable "HTTP Status 500" error! (see bottom for
the full error message).
I try to debug deep into
org.eclipse.birt.data.oda.util.manifest.ManifestExplorer.get ExtensionManifes
t(String extensionId) to see if my plugin got resolved. It seems that the
getExtensionManifest() method works if it gets call in the main Eclipse UI
thread (so I've no problem in setting up datasource and dataset). Then,
Eclipse runs preview (with Tomcat server?) in a separate thread , and
getExtensionManifest() can not resolve my plugin correctly.
I also export my plugin to BIRT RCP designer. Again, I have no problem to
set up my own data source and data set, but the designer has the same
problem on preview.
Can anyone tell me how to get preview operation to recognise my plugin?
Please help.
Many thanks.
Tony.
IT Professional - Australian Nuclear Science and Technology Organisation.
Important: This transmission is intended only for the use of the addressee.
It is confidential and may contain privileged information or copyright
material. If you are not the intended recipient, any use or further
disclosure of this communication is strictly forbidden. If you have received
this transmission in error, please notify me immediately by telephone and
delete all copies of this transmission as well as any attachments.
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
java.lang.IllegalArgumentException: The extension with ID
'org.gumtree.gumnut.report.dataSource2' is not found!
org.eclipse.birt.report.model.extension.oda.ODAManifestUtil. getDataSourceExt
ension(ODAManifestUtil.java:51)
org.eclipse.birt.report.model.parser.OdaDataSourceState.pars eODADataSourceEx
tensionID(OdaDataSourceState.java:104)
org.eclipse.birt.report.model.parser.OdaDataSourceState.pars eAttrs(OdaDataSo
urceState.java:54)
org.eclipse.birt.report.model.parser.DesignParserHandler.sta rtElement(Design
ParserHandler.java:87)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Ab
stractSAXParser.java:533)
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyEl
ement(AbstractXMLDocumentParser.java:220)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanS
tartElement(XMLDocumentFragmentScannerImpl.java:872)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$Fragm
entContentDispatcher.dispatch(XMLDocumentFragmentScannerImpl .java:1693)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanD
ocument(XMLDocumentFragmentScannerImpl.java:368)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Con
figuration.java:834)
figuration.java:764)
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:14
8)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractS
AXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:88)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:153
org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.ja
va:157)
org.eclipse.birt.report.model.api.SessionHandle.openDesign(S essionHandle.jav
a:90)
org.eclipse.birt.report.engine.parser.ReportParser.parse(Rep ortParser.java:8
3)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(
ReportEngineHelper.java:87)
org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngin
e.java:216)
org.eclipse.birt.report.viewer.aggregation.BaseFragment.prep areAttributeBean
(Unknown Source)
at org.eclipse.birt.report.viewer.aggregation.BaseFragment.serv ice(Unknown
Source)
at org.eclipse.birt.report.viewer.servlets.ViewerServlet.doPost (Unknown
Source)
at org.eclipse.birt.report.viewer.servlets.ViewerServlet.doGet( Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(Application
FilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterCh
ain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.ja
va:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invok
eNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.ja
va:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:2
46)
eNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.
java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorRepor
tValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java
:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConne
ction(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.jav
a:683)
at java.lang.Thread.run(Thread.java:595)
Re: New datasource running on RCP [message #72834 is a reply to message #72002] |
Thu, 08 September 2005 22:53 |
Right, I need to export my plugin with that data source to
".....org.eclipse.birt.report.viewer_1.0.1\birt\plugins", but BIRT DOES NOT
support OSGi plugin?! I have to rewrite my plugin in Eclipse 3.0 mode
without OSGi support. Will the future release of BIRT solve this problem?
"Tony Lam" <calltl@hotmail.com> wrote in message
news:dfg0ki$eo$1@news.eclipse.org...
for
for
> problem on preview.
> Please help.
> Many thanks.
> Tony.
addressee.
received
> message
> exception
> at
> at
> at
> urceState.java:54)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 8)
> at
> AXParser.java:1242)
> at
> at
> at
> va:157)
> at
> a:90)
> at
> 3)
> at
> at
> e.java:216)
> at
> (Unknown Source)
> Source)
> Source)
> Source)
> at
> at
> ain.java:193)
> at
> va:256)
> at
> at
> at
> va:191)
> at
> at
> 46)
> at
> at
> at
> at
> at
> at
> java:171)
> at
> at
> tValve.java:153)
> at
> at
> at
> :174)
> at
> at
> at
> at
> at
> at
> a:683)
Re: New datasource running on RCP [message #74529 is a reply to message #72834] |
Thu, 15 September 2005 17:31 |
Wang Qiangsheng Messages: 76 Registered: July 2009 |
Member |
Hi, Tonay
Could you please file a bugzilla item for this issue?
Qiangsheng
在 Fri, 9 Sep 2005 08:53:02 +1000,Tony Lam <calltl@hotmail.com> 写道:
> NOT
> problem?
>> a
> for
> for
>> the
>> UI
>> to
>> problem on preview.
>> Please help.
>> Many thanks.
>> Regards,
>> Tony.
>> Organisation.
> addressee.
> received
>> and
>> message
>> it
>> exception
>> at
>> at
>> at
>> urceState.java:54)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> 8)
>> at
>> AXParser.java:1242)
>> at
>> at
>> at
>> va:157)
>> at
>> a:90)
>> at
>> 3)
>> at
>> at
>> e.java:216)
>> at
>> (Unknown Source)
>> at
>> Source)
>> Source)
>> Source)
>> at
>> at
>> ain.java:193)
>> at
>> va:256)
>> at
>> at
>> at
>> va:191)
>> at
>> at
>> 46)
>> at
>> at
>> at
>> at
>> at
>> at
>> java:171)
>> at
>> at
>> tValve.java:153)
>> at
>> at
>> at
>> :174)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> a:683)
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
FUDForum. Page generated in 0.02021 seconds
