Re: Draw2D fill arc in CHORD [message #703314 is a reply to message #700097] |
Wed, 27 July 2011 12:40 |
Originally posted by:
that the fill arc works differently from RCP looks like a bug, either in
the Draw2D adoption of RAP or in RAP's GC implementation. Would you mind
to file a bug report?
For the things currently missing i RAP, you may want to file an
enhancement request. For GC(Image) there is already one:
318900: Image class doesn't implement Drawable
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318900
Rüdiger
On 22.07.2011 22:38, Xihui Chen wrote:
> In RAP, draw2d fill arc in Chord, which is different from RCP. Do we have any solution?
> BTW, here are some other things I found that are not supported in RAP Draw2D:
> No Dash line.
> No Pattern
> No Tooltip
> Doesn't support Clip
> No GC(Image)
> The RepeatFiringBehavior of ButtonModel doesn't work, because Display.getCurrent() should not be called from non-UI thread.
> In RCP:
> In RAP (notice the Arc widget on upper right part:
Rüdiger Herrmann
Twitter: @EclipseRAP
FUDForum. Page generated in 0.03000 seconds
