Home » Eclipse Projects » BIRT » How do I do multi-select parameter?
How do I do multi-select parameter? [message #699634] Fri, 22 July 2011 00:50 Go to next message
Brian Lavender is currently offline Brian LavenderFriend
What is the latest for creating a multi-select parameter? Is it baked into Birt now?
select name, state, zip, phone
from
people
where state in ('AZ','CA','NY','UT');
I want the user to be presented with a dynamically generated list and he selects multiple states from the list.
brian
(no subject) [message #699941 is a reply to message #699634] Fri, 22 July 2011 15:12 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Brian,
You can do this with a dataset filter or a little script in the
beforeOpen event of the datasource. I prefer the script as it pushes
down the in clause to the db. Take a look at the attached example.
Jason
> into Birt now?
> select name, state, zip, phone from
> people
> brian
Re: (no subject) [message #702880 is a reply to message #699941] Tue, 26 July 2011 23:00 Go to previous messageGo to next message
Great. Thanks for the example. The "Before Open" property is a little obscure, but it works. It took me a while to find it.
Re: (no subject) [message #716806 is a reply to message #699941] Thu, 18 August 2011 14:01 Go to previous messageGo to next message
gavinR  is currently offline gavinR Friend
Hello again Jason,
Do you have a similar report to this one, that is compatible with v2.3.2?
I have hit the same issue as Brian Sad
Gavin
Jason Weathersby wrote on Fri, 22 July 2011 11:12
Brian,
Jason
Re: (no subject) [message #716817 is a reply to message #716806] Thu, 18 August 2011 14:06 Go to previous messageGo to next message
It is attached. I also attached how to do this if the where component
requires an integer.
Jason
On 8/18/2011 10:01 AM, gavinR wrote:
> Hello again Jason,
> I have hit the same issue as Brian :(
> Gavin
>> Brian,
>> Jason
  • Attachment: querymod.zip
    (Size: 5.76KB, Downloaded 307 times)
Re: (no subject) [message #716820 is a reply to message #716806] Thu, 18 August 2011 14:06 Go to previous messageGo to next message
Jason
> Hello again Jason,
> Gavin
>> Brian,
>> Jason
    (Size: 5.76KB, Downloaded 290 times)
Re: (no subject) [message #989401 is a reply to message #699941] Thu, 06 December 2012 05:34 Go to previous messageGo to next message
Nihar Narla is currently offline Nihar NarlaFriend
Hi , I am new to BIRT,, Confused
Can u please explain me how did u do that parameter selection ..
I need the same logic for my report....
Please reply ASAP ,, very urgent ,,, Smile
Thank you
Nihar Narla
Re: (no subject) [message #989554 is a reply to message #989401] Thu, 06 December 2012 17:26 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
Hi Nihar,
Where are you currently stuck at with this? Have you looked at the report above?
Michael
Developer Evangelist, Silanis
Previous Topic:Is it possible to create dynamic datasets and how do I do this?
Next Topic:Scaling X-Axis
Current Time: Fri Apr 27 05:02:37 GMT 2018
Powered by FUDForum. Page generated in 0.23204 seconds
