Home » Newcomers » Newcomers » ImageJ Flood Fill(ImageJ Flood Fill)
ImageJ Flood Fill [message #699467] |
Thu, 21 July 2011 15:23 |
Colin White Messages: 2 Registered: July 2011 |
Junior Member |
I've written a short program to flood fill a simple black and white image of the outline of a cell (I'm using ImageJ). The image is too big to do this recursively (about 400x400 pixels) so I've used queues. However, my program only runs for a short while and then returns and out of memory error. I'm really not sure why it ends up using an upwards of 400MB of memory before it crashes.
-Colin
import ij.*;
import ij.plugin.filter.PlugInFilter;
import ij.process.*;
import ij.gui.*;
import java.awt.*;
import java.util.*;
import java.lang.Math.*;
public class Filopodia_Analyzer implements PlugInFilter{
ImagePlus analyzed;
public int setup(String arg, ImagePlus analyzed){
return DOES_ALL;
public void run(ImageProcessor anal_ip){
Point n = new Point();
ArrayDeque<Point> q = new ArrayDeque<Point>();
if(anal_ip.getPixelValue(12, 10) == 255.0) q.offer(new Point(12, 10));
while(q.size() != 0){
n = q.poll();
if(anal_ip.getPixelValue(n.x, n.y) == 255.0) anal_ip.putPixel(n.x, n.y, 223);
if(anal_ip.getPixelValue(n.x-1, n.y) == 255.0) q.offer(new Point(n.x-1, n.y));
if(anal_ip.getPixelValue(n.x+1, n.y) == 255.0) q.offer(new Point(n.x+1, n.y));
if(anal_ip.getPixelValue(n.x, n.y-1) == 255.0) q.offer(new Point(n.x, n.y-1));
if(anal_ip.getPixelValue(n.x, n.y+1) == 255.0) q.offer(new Point(n.x, n.y+1));
analyzed.updateAndDraw();
Re: ImageJ Flood Fill [message #699495 is a reply to message #699467] |
Thu, 21 July 2011 16:18 |
Is this an Eclipse question?
On 21-Jul-11 09:23, Colin White wrote:
> -Colin
> import ij.*; import ij.plugin.filter.PlugInFilter; import ij.process.*;
> import ij.gui.*; import java.awt.*; import java.util.*; import
> java.lang.Math.*;
> public class Filopodia_Analyzer implements PlugInFilter{ ImagePlus
> analyzed;
> public int setup(String arg, ImagePlus analyzed){ return DOES_ALL; }
> while(q.size() != 0){ n = q.poll(); if(anal_ip.getPixelValue(n.x, n.y)
> n.y)); if(anal_ip.getPixelValue(n.x+1, n.y) == 255.0) q.offer(new
> Point(n.x+1, n.y)); if(anal_ip.getPixelValue(n.x, n.y-1) == 255.0)
> q.offer(new Point(n.x, n.y-1)); if(anal_ip.getPixelValue(n.x, n.y+1) ==
> 255.0) q.offer(new Point(n.x, n.y+1)); analyzed.updateAndDraw(); } } }
Re: ImageJ Flood Fill [message #699553 is a reply to message #699525] |
Thu, 21 July 2011 18:36 |
On 21-Jul-11 11:28, Colin White wrote:
> It was more a general java question about why my program was using so
> much memory, but I managed to figure out my problem anyway. ImageJ has a
> class that can perform flood fill.
> Colin
There are really far better forums for Java questions like JavaRanch,
stackOverflow and JGuru. Glad you figured it out!
Current Time: Thu Apr 25 10:56:19 GMT 2024
Powered by FUDForum. Page generated in 0.07437 seconds
