Home » Newcomers » Newcomers » Android Developer Tools can not be installed
Android Developer Tools can not be installed [message #699129] Wed, 20 July 2011 18:09 Go to next message
cceal  is currently offline cceal
i have installed the other components using eclipse except for Android Developer Tools how do i solve this problem?
this message keeps on appearing:
Cannot complete the install because one or more required items could not be found.
Software being installed: Android Development Tools 12.0.0.v201106281929-138431 (com.android.ide.eclipse.adt.feature.group 12.0.0.v201106281929-138431)
Missing requirement: Android Development Tools 12.0.0.v201106281929-138431 (com.android.ide.eclipse.adt.feature.group 12.0.0.v201106281929-138431) requires 'org.eclipse.gef 0.0.0' but it could not be found
[Updated on: Wed, 20 July 2011 18:09]
Report message to a moderator
Re: Android Developer Tools can not be installed [message #699510 is a reply to message #699129] Thu, 21 July 2011 12:50 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
As you might have found out yourself this is about Android Tools and
hence it would make more sense to ask on one of their forums.
Dani
> not be found.
> could not be found[/color]
Re: Android Developer Tools can not be installed [message #702973 is a reply to message #699510] Tue, 26 July 2011 22:12 Go to previous messageGo to next message
nickbrower is currently offline nickbrower
I am having this problem too.
I am trying to follow the "Installing the ADT Plugin" for the android from the android setup guide at <cant post a link cause im a noob>
and they give you two routes to follow:
1.
Start Eclipse, then select Help > Install New Software....
Click Add, in the top-right corner.
In the Add Repository dialog that appears, enter "ADT Plugin" for the Name and the following URL for the Location:
Click OK
Note: If you have trouble acquiring the plugin, try using "http" in the Location URL, instead of "https" (https is preferred for security reasons).
In the Available Software dialog, select the checkbox next to Developer Tools and click Next.
In the next window, you'll see a list of the tools to be downloaded. Click Next.
Read and accept the license agreements, then click Finish.
Note: If you get a security warning saying that the authenticity or validity of the software can't be established, click OK.
When the installation completes, restart Eclipse.
OR 2.
If you are having trouble downloading the ADT plugin after following the steps above, here are some suggestions:
If Eclipse can not find the remote update site containing the ADT plugin, try changing the remote site URL to use http, rather than https. That is, set the Location for the remote site to:
If you are behind a firewall (such as a corporate firewall), make sure that you have properly configured your proxy settings in Eclipse. In Eclipse, you can configure proxy information from the main Eclipse menu in Window (on Mac OS X, Eclipse) > Preferences > General > Network Connections.
If you are still unable to use Eclipse to download the ADT plugin as a remote update site, you can download the ADT zip file to your local machine and manually install it:
Download the current ADT Plugin zip file from the table below (do not unpack it).
Name Package Size MD5 Checksum
ADT 12.0.0 ADT-12.0.0.zip 5651973 bytes 8ad85d0f3da4a2b8dadfddcc2d66dbcb
Follow steps 1 and 2 in the default install instructions (above).
BUT both ways lead to the same error. please help.
Re: Android Developer Tools can not be installed [message #703347 is a reply to message #702973] Wed, 27 July 2011 09:29 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
Please post Android questions on Android forums. This is an Eclipse forum. Eclipse forums do not provide Android support.
Re: Android Developer Tools can not be installed [message #710015 is a reply to message #699129] Thu, 04 August 2011 11:37 Go to previous messageGo to next message
Kevin  is currently offline Kevin
At the available software window, click on the link "Available software sites".
You need two items checked, the Android Plugin that you added and the download.eclipse.org/releases/helios or galilio if that is your version of eclipse. Click ok to go back to the available software window.
Now select Work with: Android plugin.
Now click next continuing with install.
I followed the instruction from
fedoraproject.org/wiki/HOWTO_Setup_Android_Development
I had skipped checking the release/helios and got the errors that you did. When I check the release/helios I was able to install ok.
Re: Android Developer Tools can not be installed [message #717046 is a reply to message #710015] Fri, 19 August 2011 03:07 Go to previous messageGo to next message
jteko360 is currently offline jteko360
Try this. go to Window> Preferences > General > Network Connections.
Change the Active Provider drop-down choice to 'direct'.All the best.
Re: Android Developer Tools can not be installed [message #739070 is a reply to message #717046] Sun, 16 October 2011 23:58 Go to previous messageGo to next message
James White is currently offline James White
"Try this. go to Window> Preferences > General > Network Connections.
Change the Active Provider drop-down choice to 'direct'.All the best."
This worked for me. Thank you I appreciate it.
[Updated on: Sun, 16 October 2011 23:59]
Re: Android Developer Tools can not be installed [message #748559 is a reply to message #710015] Mon, 24 October 2011 15:07 Go to previous message
Mike  is currently offline Mike
Thanks Kevin, adding the additional sources as you specified worked for me.
Previous Topic:Cannot launch debugger from Eclipse
Next Topic:Eclipse Helios Deployment Issue
Current Time: Sat May 18 19:00:53 EDT 2013
Powered by FUDForum. Page generated in 0.01773 seconds
