Home » Modeling » M2T (model-to-text transformation) » [Acceleo] EEnum access from a module
[Acceleo] EEnum access from a module [message #699030] Wed, 20 July 2011 17:11 Go to next message
Carlos Gomez is currently offline Carlos GomezFriend
Member
Hi everybody!!
I'm using Acceleo to M2T. I'm trying to compare a chosen value in my model and a literal from a EEnum from my MM ecore.
How can I access to my defined "EEnum" from my template module if my module input type is the root EClass of my MM?
My EEnum and my EClass are in the same EPackage and I use EEnum to give a "Type" to an attribute of one of my EClass in my MM.
Thanks for your help!!
Re: [Acceleo] EEnum access from a module [message #699254 is a reply to message #699030] Thu, 21 July 2011 08:11 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
Hi Carlos,
This is one of the things that is "not so obvious" in OCL; I has outlined how to compare EEnum literals on http://eclipsemde.blogspot.com/2010/04/ocl-tips-and-tricks.html .
Does that help?
Laurent Goubet
Obeo
Previous Topic:Help/Doc reference for "file" directive
Next Topic:[MWE] Use metamodel from other plugin
Current Time: Sat Feb 24 08:40:23 GMT 2018
Powered by FUDForum. Page generated in 0.02907 seconds
