Home » Eclipse Projects » Plugin Development Environment (PDE) » class.getClassLoader().getResource is not working(class.getClassLoader().getResource is not working while trying to get file list from a jar file in using eclipse plugin)
class.getClassLoader().getResource is not working [message #698807] Wed, 20 July 2011 09:00 Go to next message
swastika is currently offline swastikaFriend
We wrote an eclipse plugin in which need to get list of files from a jar file
to get the list of the files present we are using the following way
URL propertiesURL = MyClass.class.getClassLoader().getResource(
"resourcename");
But the propertiesURL doesnt return the correct path. Is there any other alternative available for this? Any input will be very much helpful to us.
Thanks.
Re: class.getClassLoader().getResource is not working [message #699217 is a reply to message #698807] Thu, 21 July 2011 05:48 Go to previous message
Adam Lucarz is currently offline Adam LucarzFriend
in a bundle/plug-in context you have to use Activator.getDefault().getBundle().getEntry("resourcename") to get the right url. But be careful because the url is different concerning if the bundle is jarred or not.
By the way: Resources from within a jar are copied temporary to the active workspace. That is the target location which will be returned by the method mentioned above.
Greetings
Adam
Previous Topic:org.w3c.dom.Node method calls returning null values
Next Topic:Error while exporting product: host fragment not found
Current Time: Thu May 24 19:36:52 GMT 2018
Powered by FUDForum. Page generated in 0.02866 seconds
