[GEF] Thumbnail + direct edit issues [message #698798] |
Wed, 20 July 2011 08:41  |
Arnaud MERGEY Messages: 220 Registered: March 2010 Location: France |
In GEF incubator, trying to display a thumbnail in Outline View, instead of Thumbnail, there is a black rectangle
I attach a single sourced snippet, so I have checked it worked with RCP.
To reproduce, launch the application and double-click on an item in the left tree
to open the GEF editor.
In RCP the Thumbnail is correctly displayed in Outline, in RAP it is black
The editor source is here in the snippet:
/snippet.gef.sample2/src/snippet/gef/sample2/ModelDesignGraphEditor.java
Also another issue That can be checked with this snippet, but I have seen it as well in org.eclipse.rap.gef.demo demo bundle
Direct Edit request does not seems to be send to the graphical edit part.
For example in the snippet if you select, then click on "Entity_0" label in blue shape, in RCP you can change the value, in RAP you cannot.
By debugging in RAP
snippet.gef.sample2.gef.part.EntityPart.performRequest(Request) is not called.
[Updated on: Wed, 20 July 2011 08:41] Report message to a moderator
FUDForum. Page generated in 0.01882 seconds
