[XPand]trying to start Xpand from a plugin [message #698353] |
Tue, 19 July 2011 10:16 |
st oehm Messages: 79 Registered: October 2009 |
Member |
update: forget about the question, i have to do some reorganization (so it can't work)
hi,
i try to run my xpand project from a plugin.
i did this:
exported the xpand Project as jar
imported it into the plug in project
copied the plugindepencies from the xpand project to the plugin project
i have run the plugin in a new eclipseinstance and it causes no errors but nothing happens, i let printed out the workflowrun-command and it was false (with this:
WorkflowRunner wr = new WorkflowRunner();
ProgressMonitor p = new org.eclipse.emf.mwe.core.monitor.NullProgressMonitor();
System.out.println(wr.run(wfFile, p, properties, slotContents))
(i didn't use XpandFacade here, but it should work)
when i start it from another xpand project it works, but not from the pluginproject
has anybody an idea why the workflow do nut run
best regards
stoehm
[Updated on: Wed, 20 July 2011 09:47] Report message to a moderator
FUDForum. Page generated in 0.01842 seconds
