Home » Archived » Visual Editor (VE) » Cannot use VE ...
Re: Cannot use VE ... [message #72340 is a reply to message #71350] |
Mon, 22 November 2004 11:02 |
Originally posted by: pieter_b52.yahoo.com
I have the exact same error when loading a visual class on my sourcemage linux box
~/workspace/.metadata/.log is 1104kB though, so append here seems a little extreme :)
can I attach 8kB bzip2 ?
On Thu, 11 Nov 2004 13:38:29 +0100
JuRu <jr_c_2001fr@yahoo.fr> wrote:
> Joe Winchester a écrit :
> > Hi JuRu,
> >> I can't use VE because it says to me that :
> >> An internal error occurred during: "Create Remote VM for Visual Editor
> >> for Java".
> > Is there anything in the .log file in the .metadata directory ?
> > What JRE level are you using ? I believe on older Linux JVMs there is a
> > problem with the socket creation, and also some firewalls create
> > problems although Rich Kulp knows more about this than me.
> > However the .log file is important so please post its contents.
> > Best regards,
> > Joe Winchester
> Hi !
> Thanks for answering...
> This is the error givent by Eclipse :
> Une erreur interne s'est produite pendant : "Create Remote VM for Visual
> Editor for Java".
> java.lang.NullPointerException
> org.eclipse.jem.internal.proxy.remote.REMRegistryController. getMasterSocketPort(REMRegistryController.java:172)
> org.eclipse.jem.internal.proxy.remote.LocalProxyLaunchDelega te.launch(LocalProxyLaunchDelegate.java:163)
> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:569)
> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:150)
> org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:480)
> org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:291)
> org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:223)
> org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup$CreateRegistry.run(JavaVisualEditorPart.java: 1327)
> org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
> I'm using j2sdk1.4.2_06 for Linux.
> Best regards,
> JuRu
Pieter Lenaerts
maintainer of editors and wm's - Sourcemage GNU/linux
http://www.sourcemage.org
e-type@cwazy.co.uk
MSN: pieter_b52@yahoo.com
jabber: e-type@jabber.org
irc: irc.freenode.net #sourcemage
Re: Cannot use VE ... [message #72374 is a reply to message #72340] |
Mon, 22 November 2004 14:23 |
Clear the .log (delete it), and try to open the VE ... you should have a smaller .log.
Re: Cannot use VE ... [message #72389 is a reply to message #72374] |
Mon, 22 November 2004 15:24 |
On Mon, 22 Nov 2004 09:23:15 -0500
first thing I did
Pieter Lenaerts
e-type@cwazy.co.uk
Re: Cannot use VE ... [message #72501 is a reply to message #72374] |
Tue, 23 November 2004 10:11 |
since it had crossed my mind that a fresh log might be smaller, I already had deleted my log
trying to run the VE gives me the 1104kB log, so I uploaded the 8kB bzip2
anyone can fetch it at http://users.pandora.be/e-type/ErrorlogEclipseVE.bz2
any help welcome since I'm an illiterate to eclipse's inside :)
Pieter
Pieter Lenaerts
e-type@cwazy.co.uk
Re: Cannot use VE ... [message #72537 is a reply to message #72519] |
Tue, 23 November 2004 15:58 |
hi peter,
thx you for your time. I hope it's not going to be some lame thing I've done wrong, but the point is that my VM works fine in firefox for example.
the VE gives the same error as root as with normal users, so it's not a permissions issue
about the log: I don't mean to be rude of course, but the file is okay, I just double-checked it:
downloaded it, bunzip2'ed it and had a look
I've put it there in a .zip now too: http://users.pandora.be/e-type/ErrorlogEclipseVE.zip
12kB file
contents of the zip is textfile: ErrorlogEclipseVE
I unzipped it with winzip using wine to check if you'll be able to open it
maybe that helps?
pieter
On Tue, 23 Nov 2004 06:42:13 -0500
Peter Walker <walkerp@us.ibm.com> wrote:
> Pieter,
> The zip file contains an empty file called ErrorlogEclipseVE (byte size is
> zero). Please try again and I'll take a look at your log file.
> Regards...
> Peter Walker
> Eclipse VE Development
> > Pieter
Pieter Lenaerts
e-type@cwazy.co.uk
Re: Cannot use VE ... [message #72777 is a reply to message #72537] |
Fri, 26 November 2004 07:42 |
allright, I found the solution in here:
> From: Rich Kulp <richkulp@us.NO_SPAM.ibm.com>
> Newsgroups: eclipse.tools.ve
> Subject: Re: Eclipse - VE error
> Date: Wed, 20 Oct 2004 11:31:34 -0400
> Organization: EclipseCorner
> User-Agent: Mozilla Thunderbird 0.8 (Windows/20040913)
> It had a problem creating a socket connection. Where there any other
> errors in the log? There should of been.
> I don't know if Gentoo is anything like SUSE, but if it is, take a look
> in the etc/.hosts file. Is there any entry like:
> ::1 localhost ..some other stuff...
> If there is, you need to modify it so that localhost is not listed on
> the ::1 line. It should be listed ONLY on the 127.0.0.1 line.
my single line /etc/hosts file looked like this:
127.0.0.1 e-box
and I changed that to:
127.0.0.1 localhost e-box
then ran eclipse, opened a visual class and tadaaa!
On Tue, 23 Nov 2004 16:58:27 +0100
Pieter Lenaerts <pieter_b52@yahoo.com> wrote:
> hi peter,
> 12kB file
> maybe that helps?
> pieter
> > Pieter,
> > Regards...
> > Peter Walker
> > > Pieter
> Pieter Lenaerts
> e-type@cwazy.co.uk
Pieter Lenaerts
e-type@cwazy.co.uk
Re: Cannot use VE ... [message #603237 is a reply to message #71350] |
> > Hi JuRu,
> >> for Java".
> > Best regards,
> > Joe Winchester
> Hi !
> Editor for Java".
> Best regards,
> JuRu
Pieter Lenaerts
e-type@cwazy.co.uk
Re: Cannot use VE ... [message #603255 is a reply to message #72374] |
first thing I did
Pieter Lenaerts
e-type@cwazy.co.uk
Re: Cannot use VE ... [message #603291 is a reply to message #72374] |
Pieter
Pieter Lenaerts
e-type@cwazy.co.uk
Re: Cannot use VE ... [message #603298 is a reply to message #72519] |
hi peter,
12kB file
maybe that helps?
pieter
> Pieter,
> Regards...
> Peter Walker
> > Pieter
Pieter Lenaerts
e-type@cwazy.co.uk
Re: Cannot use VE ... [message #603339 is a reply to message #72537] |
127.0.0.1 e-box
> hi peter,
> 12kB file
> maybe that helps?
> pieter
> > Pieter,
> > Regards...
> > Peter Walker
> > > Pieter
> Pieter Lenaerts
> e-type@cwazy.co.uk
Pieter Lenaerts
e-type@cwazy.co.uk
Current Time: Thu Apr 25 21:57:12 GMT 2024
Powered by FUDForum. Page generated in 0.04151 seconds
