Re: One object in two resources [message #697119 is a reply to message #697067] |
Fri, 15 July 2011 14:57 |
Ed Merks Messages: 33140 Registered: July 2009 |
Ed,
There is support for cross document containment. I.e., a child object
can be in a different from its container object. That's supported only
in the case that EReference.resolveProxies is true and, for generated
models, if the GenModel's Containment Proxies is set to true.
On 15/07/2011 6:03 AM, Ed Willink wrote:
> Hi
> EMF accurately supports a single containment paradigm. If you want
> multiples, you should use references rather than containment.
> Regards
> Ed Willink
> On 15/07/2011 12:00, Ricky de Klerck wrote:
>> Okay, here's the situation:
>> We have one tableviewer with all persons. This is a seperate view
>> with an editing domain and commandstack. The persons are in a
>> resource. All persons are stored in a Oracle database and it's
>> connection is set with Teneo Hibernate.
>> We want to open one person in a editor with a seperate resource. This
>> is done with a URI to a single object. This way we have a single
>> commandstack per editor. The thing is, when we load this single
>> resource, the person in the parentresource (where all persons are
>> loaded) is gone... Is it not possible to have the same object in
>> multiple resources? Or is there another way to achieve what we want??
>> Anyone? Thanks in advance.
>> Regards,
>> Rick
Ed Merks
FUDForum. Page generated in 0.03165 seconds
