Home » Archived » Buckminster » Problems installing Buckminster on Indigo
Problems installing Buckminster on Indigo [message #696830] |
Thu, 14 July 2011 22:34 |
Koos de Goede Messages: 31 Registered: July 2009 |
Member |
Hi All,
I encountered problems installing Buckminster on Indigo from
http://download.eclipse.org/tools/buckminster/updates-3.7
I followed the instructions of the CDO source installation and created a new
Eclipse installation and only installed the CDO required features. However
when trying to install Buckminster I have the folowing errors. (I also tried
some archives found on the Buckminster download page which gave the same
erros)
help is appriciated, Koos
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile,
phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=,
action=).
Retry another mirror
Problems downloading artifact:
osgi.bundle,org.eclipse.buckminster.model.common,1.1.0.v20110629-1242.
Unpacking fails because intermediate file is empty:
C:\DOCUME~1\Koos\LOCALS~1\Temp\work25645\p2.optimizers.incoming25640.jar
osgi.bundle,org.eclipse.buckminster.model.common.edit,1.1.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work23950\p2.optimizers.incoming23944.jar
osgi.bundle,org.eclipse.buckminster.mspec,1.1.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work24425\p2.optimizers.incoming24413.jar
osgi.bundle,org.eclipse.buckminster.mspec.edit,1.1.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work24072\p2.optimizers.incoming24070.jar
osgi.bundle,org.eclipse.buckminster.mspec.editor,1.0.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work25361\p2.optimizers.incoming25358.jar
osgi.bundle,org.eclipse.buckminster.rmap,1.1.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work25812\p2.optimizers.incoming25809.jar
osgi.bundle,org.eclipse.buckminster.rmap.edit,1.1.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work24442\p2.optimizers.incoming24439.jar
osgi.bundle,org.eclipse.buckminster.rmap.editor,1.0.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work25896\p2.optimizers.incoming25892.jar
osgi.bundle,org.eclipse.buckminster.rmap.pde,1.0.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work26285\p2.optimizers.incoming26284.jar
osgi.bundle,org.eclipse.buckminster.rmap.pde.edit,1.0.0.v20110629-1242.
C:\DOCUME~1\Koos\LOCALS~1\Temp\work25701\p2.optimizers.incoming25698.jar
Re: Problems installing Buckminster on Indigo [message #696969 is a reply to message #696830] |
Fri, 15 July 2011 08:12 |
Sounds like you encountered some kind of network problem. I just tried to install Buckminster into a fresh Indigo IDE
installation from http://download.eclipse.org/tools/buckminster/updates-3.7 and everything installed without problems so
our update site is OK.
- thomas
On 2011-07-15 00:34, Koos de Goede wrote:
> Hi All,
> erros)
> action=).
Re: Problems installing Buckminster on Indigo [message #697085 is a reply to message #696969] |
Fri, 15 July 2011 13:15 |
Member |
Hi Thomas,
Thanks for your quick answer. I dowloaded a fresh Indigo and tried the
install again but stil have the same error as below at the same point.
Yesterday I have dowloaded several archives from:
http://archive.eclipse.org/tools/buckminster/archivedsites-3.7/
containing an update site which I stored locally having the same errors as
shown below, all other installs such as EMF/GMF and other install wothout
errors.
Is there somewhere a zip available which I can install the old way? e.g.
unpack and run eclipse with -clean?
Koos
"Thomas Hallgren" <thomas@tada.se> wrote in message
news:ivos7h$ikm$1@news.eclipse.org...
> install Buckminster into a fresh Indigo IDE installation from
> installed without problems so our update site is OK.
> - thomas
>> Hi All,
>> new
>> However
>> tried
>> erros)
>> action=).
Re: Problems installing Buckminster on Indigo [message #697086 is a reply to message #697085] |
Fri, 15 July 2011 13:38 |
What type of JVM are you using? Is it very old? From the looks of it the install might fail when unpacking the pack200
files.
On 2011-07-15 15:15, Koos de Goede wrote:
> Hi Thomas,
> errors.
No, sorry. That's not a viable approach in a modern eclipse.
- thomas
Current Time: Thu Apr 18 12:39:34 GMT 2024
Powered by FUDForum. Page generated in 0.01943 seconds
