(no subject) [message #696984 is a reply to message #696824] |
Fri, 15 July 2011 09:03 |
Originally posted by:
as far as I know, there is no way to programmatically control the width
of the perspective bar.
You may, however ask on the RCP Form and see there if someone knows a
workaround for this.
HTH
Rüdiger
On 15.07.2011 00:16, jamie wrote:
> I created a brand new project using the Hello World template for eclipse
> RAP.
> I have two perspectives that I added to the workbench. I've enabled the
> setShowPerspectives to true however the actual buttons dont appear until
> I click the + drop down button. And once they are added the width of the
> perspectives bar is so small that it only shows one perspective button
> instead of two.
> Is there any way to enforce the perspective buttons to always show in
> the top bar.
Rüdiger Herrmann
Twitter: @EclipseRAP
Re: (no subject) [message #697361 is a reply to message #697000] |
Sat, 16 July 2011 11:28 |
Jamie,
I don't know of a configuration option that controls the width of the
perspective bar either. Theming or branding definitely don't offer to
influence the perspective bar.
As I said, you may find an answer in the RCP forum.
Rüdiger
On 15.07.2011 11:54, jamie wrote:
> I don't need to programmatically control the width. If there is a config
> file I can edit then that would be just as good.
> I'm not sure if this is done via branding or theming.
Rüdiger Herrmann
FUDForum. Page generated in 0.03395 seconds
