How can I view SWT Image while debugging? [message #696288] |
Wed, 13 July 2011 16:15  |
I added a breakpoint on my SWT-based application, and when Eclipse stops at it during a debug session I want to view the image referenced by an Image variable.
If I right click the variable and choose watch or inspect, all I see is what is returned from Image's toString method.
Is it possible?
Mário Marinato
From Brazil
Re: How can I view SWT Image while debugging? [message #714250 is a reply to message #696288] |
Wed, 10 August 2011 06:44   |
Vijay Raj Messages: 608 Registered: July 2009 |
It all depends on how important and usefull is this requirement.
A plugin can be written to view the image in the outline view or in a seperate view.
If at all more people require this..will try to impliment this.
Intrested ppl please vote.
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
(no subject) [message #714641 is a reply to message #714530] |
Thu, 11 August 2011 07:14  |
Originally posted by:
On 2011-08-10 20:33, Thomas Singer wrote:
> I'd write a utility method which saves the file to disk (and optionally
> launches the graphic application to view it). When debugging, you can
> execute this method easily with the image variable as parameters.
I agree. I have solved similar problems exactly in that way.
- Daniel
FUDForum. Page generated in 0.01852 seconds
