Home » Newcomers » Newcomers » Introspection using Reflection(Introspection using Reflection)
Introspection using Reflection [message #695157] Mon, 11 July 2011 06:36
Vineet  is currently offline Vineet Friend
I am using the below code for introspection of a package
package groupHistory;
import java.io.File;
import java.io.IOException;
import java.net.URL;
import java.util.ArrayList;
import java.util.Enumeration;
import java.util.List;
* Scans all classes accessible from the context class loader which belong to the given package and subpackages.
* @param packageName The base package
* @return The classes
* @throws ClassNotFoundException
* @throws IOException
class Temporary1{
public static Class[] getClasses(String packageName)
throws ClassNotFoundException, IOException {
ClassLoader classLoader = Thread.currentThread().getContextClassLoader();
assert classLoader != null;
String path = packageName.replace('.', '/');
System.out.println(path);
Enumeration<URL> resources = classLoader.getResources(path);
List<File> dirs = new ArrayList<File>();
while (resources.hasMoreElements()) {
URL resource = resources.nextElement();
dirs.add(new File(resource.getFile().replace("%20", " ")));
ArrayList<Class> classes = new ArrayList<Class>();
for (File directory : dirs) {
classes.addAll(findClasses(directory, packageName));
return classes.toArray(new Class[classes.size()]);
* Recursive method used to find all classes in a given directory and subdirs.
* @param directory The base directory
* @param packageName The package name for classes found inside the base directory
public static List<Class> findClasses(File directory, String packageName) throws ClassNotFoundException {
System.out.println(directory.exists());
if (!directory.exists()) {
return classes;
File[] files = directory.listFiles();
for (File file : files) {
if (file.isDirectory()) {
assert !file.getName().contains(".");
classes.addAll(findClasses(file, packageName + "." + file.getName()));
} else if (file.getName().endsWith(".class")) {
classes.add(Class.forName(packageName + '.' + file.getName().substring(0, file.getName().length() - 6)));
return classes;
public class Temporary{
try{
Class[] classes = Temporary1.getClasses(".");
System.out.println(classes.length);
for (int i = 0; i < classes.length; i++) {
System.out.println(classes[i].getName());
System.out.println();
System.out.println("I am done ");
}catch(Exception e){System.out.println(e.getMessage());}
But the problem is I wanna get all the classes available in a project in Eclipse because I will get to know that only.
How can achieve this using java code
Previous Topic:Eclipse not working on Windows 7
Next Topic:Performance Issue
Current Time: Tue Jan 23 17:20:47 GMT 2018
Powered by FUDForum. Page generated in 0.02935 seconds
