Trying to build stub code for a WSDL that forces SSL and uses a self-signed cert [message #693968] |
Thu, 07 July 2011 14:53 |
ben may Messages: 12 Registered: July 2011 |
Junior Member |
Hey all! I am trying to generate stub code in eclipse for the following WSDL:
https://ctms-services-pa-3-3.nci.nih.gov:1523/wsrf/services/cagrid/TrialRegistrationService?wsdl
This server forces https and uses a self-signed cert. The WSDL itself is basically just a reference to two other WSDL's on the same server:
<wsdl:definitions xmlns:binding="http://enterpriseservices.nci.nih.gov/PAServices/TrialRegistrationService/bindings" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/" xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" name="TrialRegistrationService" targetNamespace="http://enterpriseservices.nci.nih.gov/PAServices/TrialRegistrationService/service">
<wsdl:import location="https://ctms-services-pa-3-3.nci.nih.gov:1523/wsrf/share/schema/PAServices/TrialRegistrationService_bindings.wsdl" namespace="http://enterpriseservices.nci.nih.gov/PAServices/TrialRegistrationService/bindings"/>
<wsdl:service name="TrialRegistrationService">
<wsdl:port binding="binding:TrialRegistrationServicePortTypeSOAPBinding" name="TrialRegistrationServicePortTypePort">
<soap:address location="https://ctms-services-pa-3-3.nci.nih.gov:1523/wsrf/services/cagrid/TrialRegistrationService"/>
</wsdl:port>
</wsdl:service>
</wsdl:definitions>
I've tried saving the code above locally and adding that as a WSDL file to my project, but then I get this error:
IWAB0399E Error in generating Java from WSDL: javax.wsdl.WSDLException: WSDLException (at /wsdl:definitions/wsdl:import): faultCode=OTHER_ERROR: Unable to resolve imported document at 'https://ctms-services-pa-3-3.nci.nih.gov:1523/wsrf/share/schema/PAServices/TrialRegistrationService_bindings.wsdl', relative to 'file:/C:/Documents and Settings/ben/workspace/CTRP project/NewWSDLFile.wsdl': javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
Is there any way to instruct eclipse to "trust" this cert even though it's self-signed?
Thanks!
[Updated on: Thu, 07 July 2011 15:26] Report message to a moderator
Re: Trying to build stub code for a WSDL that forces SSL and uses a self-signed cert [message #698088 is a reply to message #697144] |
Mon, 18 July 2011 18:30 |
Junior Member |
Ok, so I solved this problem and I want to put the solution up here for anyone who encounters it in the future. I downloaded a java tool called InstallCert.java, which I quote here
* Copyright 2006 Sun Microsystems, Inc. All Rights Reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* - Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* - Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* - Neither the name of Sun Microsystems nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
* IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
import java.io.*;
import java.net.URL;
import java.security.*;
import java.security.cert.*;
import javax.net.ssl.*;
public class InstallCert {
public static void main(String[] args) throws Exception {
String host;
int port;
char[] passphrase;
if ((args.length == 1) || (args.length == 2)) {
String[] c = args[0].split(":");
host = c[0];
port = (c.length == 1) ? 443 : Integer.parseInt(c[1]);
String p = (args.length == 1) ? "changeit" : args[1];
passphrase = p.toCharArray();
} else {
System.out.println("Usage: java InstallCert <host>[:port] [passphrase]");
return;
File file = new File("jssecacerts");
if (file.isFile() == false) {
char SEP = File.separatorChar;
File dir = new File(System.getProperty("java.home") + SEP
+ "lib" + SEP + "security");
file = new File(dir, "jssecacerts");
file = new File(dir, "cacerts");
System.out.println("Loading KeyStore " + file + "...");
InputStream in = new FileInputStream(file);
KeyStore ks = KeyStore.getInstance(KeyStore.getDefaultType());
ks.load(in, passphrase);
in.close();
SSLContext context = SSLContext.getInstance("TLS");
TrustManagerFactory tmf =
TrustManagerFactory.getInstance(TrustManagerFactory.getDefaultAlgorithm());
tmf.init(ks);
X509TrustManager defaultTrustManager = (X509TrustManager)tmf.getTrustManagers()[0];
SavingTrustManager tm = new SavingTrustManager(defaultTrustManager);
context.init(null, new TrustManager[] {tm}, null);
SSLSocketFactory factory = context.getSocketFactory();
System.out.println("Opening connection to " + host + ":" + port + "...");
SSLSocket socket = (SSLSocket)factory.createSocket(host, port);
socket.setSoTimeout(10000);
try {
System.out.println("Starting SSL handshake...");
socket.startHandshake();
socket.close();
System.out.println();
System.out.println("No errors, certificate is already trusted");
} catch (SSLException e) {
e.printStackTrace(System.out);
X509Certificate[] chain = tm.chain;
if (chain == null) {
System.out.println("Could not obtain server certificate chain");
return;
BufferedReader reader =
new BufferedReader(new InputStreamReader(System.in));
System.out.println("Server sent " + chain.length + " certificate(s):");
MessageDigest sha1 = MessageDigest.getInstance("SHA1");
MessageDigest md5 = MessageDigest.getInstance("MD5");
for (int i = 0; i < chain.length; i++) {
X509Certificate cert = chain[i];
System.out.println
(" " + (i + 1) + " Subject " + cert.getSubjectDN());
System.out.println(" Issuer " + cert.getIssuerDN());
sha1.update(cert.getEncoded());
System.out.println(" sha1 " + toHexString(sha1.digest()));
md5.update(cert.getEncoded());
System.out.println(" md5 " + toHexString(md5.digest()));
System.out.println("Enter certificate to add to trusted keystore or 'q' to quit: [1]");
String line = reader.readLine().trim();
int k;
try {
k = (line.length() == 0) ? 0 : Integer.parseInt(line) - 1;
} catch (NumberFormatException e) {
System.out.println("KeyStore not changed");
return;
X509Certificate cert = chain[k];
String alias = host + "-" + (k + 1);
ks.setCertificateEntry(alias, cert);
OutputStream out = new FileOutputStream("jssecacerts");
ks.store(out, passphrase);
out.close();
System.out.println(cert);
System.out.println
("Added certificate to keystore 'jssecacerts' using alias '"
+ alias + "'");
private static final char[] HEXDIGITS = "0123456789abcdef".toCharArray();
private static String toHexString(byte[] bytes) {
StringBuilder sb = new StringBuilder(bytes.length * 3);
for (int b : bytes) {
b &= 0xff;
sb.append(HEXDIGITS[b >> 4]);
sb.append(HEXDIGITS[b & 15]);
sb.append(' ');
return sb.toString();
private static class SavingTrustManager implements X509TrustManager {
private final X509TrustManager tm;
private X509Certificate[] chain;
SavingTrustManager(X509TrustManager tm) {
this.tm = tm;
public X509Certificate[] getAcceptedIssuers() {
throw new UnsupportedOperationException();
public void checkClientTrusted(X509Certificate[] chain, String authType)
throws CertificateException {
public void checkServerTrusted(X509Certificate[] chain, String authType)
this.chain = chain;
tm.checkServerTrusted(chain, authType);
You pass it the server name and optional port and passphrase and it downloads and creates a cert store file for you called jssecacerts. If you copy this file into $JAVA_HOME/lib/security for the JRE that eclipse is using for its runtime, it will trust that cert and you can access the WSDL. But now I am having a different problem, for which I will create a new thread. Hopefully someone else will find this solution useful in the future.
FUDForum. Page generated in 0.03279 seconds
