Home » Eclipse Projects » Plugin Development Environment (PDE) » Errors running builder 'Plug-in Manifest Builder' on project 'com.tcs.mcif.ui.rap'.
Errors running builder 'Plug-in Manifest Builder' on project 'com.tcs.mcif.ui.rap'. [message #693881] Thu, 07 July 2011 12:41
marie Missing name is currently offline marie Missing nameFriend
Member
When I do clean and build of my projetc ,
I got the followong excpetion:
at com.sun.org.apache.xerces.internal.dom.CoreDocumentImpl.insertBefore(CoreDocumentImpl.java:414)
at com.sun.org.apache.xerces.internal.dom.NodeImpl.appendChild(NodeImpl.java:275)
at org.eclipse.pde.internal.core.builders.XMLErrorReporter.endDocument(XMLErrorReporter.java:212)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endDocument(AbstractSAXParser.java:769)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.endDocument(XMLDTDValidator.java:981)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.endEntity(XMLDocumentScannerImpl.java:560)
at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.endEntity(XMLEntityManager.java:1779)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.load(XMLEntityScanner.java:1758)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.skipSpaces(XMLEntityScanner.java:1303)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDispatcher.dispatch(XMLDocumentScannerImpl.java:784)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:368)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:834)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:764)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:148)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1242)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:176)
at org.eclipse.pde.internal.core.util.SAXParserWrapper.parse(SAXParserWrapper.java:56)
at org.eclipse.pde.internal.core.builders.DefaultSAXParser.parse(DefaultSAXParser.java:32)
at org.eclipse.pde.internal.core.builders.ManifestConsistencyChecker.validateFiles(ManifestConsistencyChecker.java:297)
at org.eclipse.pde.internal.core.builders.ManifestConsistencyChecker.validateProject(ManifestConsistencyChecker.java:223)
at org.eclipse.pde.internal.core.builders.ManifestConsistencyChecker.build(ManifestConsistencyChecker.java:157)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:629)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:172)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:203)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:255)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:258)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:311)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:343)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:144)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:242)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Can any body help me to resolve the problem.
Smile
P.S. I am using eclipse helios.
Previous Topic:Re-installing plugin with same name and version gives error.
Next Topic:NoClassDefFoundError
Current Time: Tue Jan 16 14:05:53 GMT 2018
Powered by FUDForum. Page generated in 0.01810 seconds
