Home » Eclipse Projects » Buckminster dev » [buckminster-dev] Project meta data is out of date for tools.buckminster
[buckminster-dev] Project meta data is out of date for tools.buckminster [message #692697] Tue, 05 July 2011 04:00
Originally posted by: emo
Henrik, Thomas,
Projects are required to keep meta data up to date using the MyFoundation
Portal (http://portal.eclipse.org/). The following problems were found
with this project's meta-data:
* The date for release "Indigo" is in the past, but the release is not
marked as completed. If it is completed, it should be marked as completed;
if it has been postponed, it should be given a new target date.
Previous Topic:Buckminster code-base has moved to Git
Next Topic:[buckminster-dev] SVN provider: additional folder
Current Time: Sat Feb 24 00:45:25 GMT 2018
Powered by FUDForum. Page generated in 0.01806 seconds
