Home » Eclipse Projects » EclipseLink » @GeneratedValue(strategy=GenerationType.AUTO)(How to configure the default for EclipseLink?)
@GeneratedValue(strategy=GenerationType.AUTO) [message #692531] Mon, 04 July 2011 16:58 Go to next message
Juergen Kissner is currently offline Juergen KissnerFriend
I have been playing with @GeneratedValue(strategy=GenerationType.AUTO) on various database platforms.
The HowTo on primary key generation (wiki.eclipse.org/EclipseLink/Examples/JPA/PrimaryKey) says:
"Typically, EclipseLink picks TABLE as the strategy, since it is the most portable strategy."
The adverb "Typically" seems to indicate that the strategy EclipseLink picks for GenerationType.AUTO can be configured.
Is there a way to influence EclipseLink's choice in such a way that the strategy for GenerationType.AUTO depends on the selected database platform?
--Juergen
Re: @GeneratedValue(strategy=GenerationType.AUTO) [message #698461 is a reply to message #692531] Tue, 19 July 2011 14:18 Go to previous message
James Sutherland is currently offline James SutherlandFriend
EclipseLink defines a Map of Sequence objects on the EclipseLink Session's DatabaseLogin.
The login defines a DefaultSequence which could be set using a SessionCustomizer, or in your DatabasePlatform's initialization.
I think JPA AUTO will use a Sequence named "SEQ_GEN" by default, so you could define a Sequence with this name.
There is also a method in DatabasePlatform createPlatformDefaultSequence(), which you could potentially override to default to another type of sequencing.
James : Wiki : Book : Blog : Twitter
(no subject) [message #698492 is a reply to message #692531] Tue, 19 July 2011 14:18 Go to previous message
James is currently offline JamesFriend
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Previous Topic:(no subject)
Next Topic:(no subject)
Current Time: Wed Jan 17 07:38:27 GMT 2018
Powered by FUDForum. Page generated in 0.21775 seconds
