How rename worked in AJDT1.4.1 [message #69921] |
Wed, 28 March 2007 08:51  |
Originally posted by: diezhongdie.sjtu.edu.cn
The one of new features is that rename refactoring also works in AspectJ
program. Is there any references or guidelines about its implementation?
How to make it happen in AOP program?
With kind regards! Winnie
Re: How rename worked in AJDT1.4.1 [message #69960 is a reply to message #69941] |
Wed, 28 March 2007 10:39  |
Thank you for your information. That helps me a lot
>> AspectJ
>> implementation?
> The class which implements the refactoring participant for type
> renames is AspectRenameParticipant.java in the
> org.eclipse.ajdt.internal.core.refactoring package (in the
> org.eclipse.ajdt.core plugin).
> Search the plugin.xml in this plugin to see how this rename
> participant is registered with the system.
> For information about accessing the AJDT source, see:
> http://www.eclipse.org/ajdt/developers.php#q:source
> Matt.
Re: How rename worked in AJDT1.4.1 [message #596064 is a reply to message #69941] |
>> AspectJ
>> implementation?
> Matt.
FUDForum. Page generated in 0.01778 seconds
