Home » Modeling » TMF (Xtext) » xtext2 domainmodel example: no types in contentassist
xtext2 domainmodel example: no types in contentassist [message #692101] Sun, 03 July 2011 15:12 Go to next message
amazuzu  is currently offline amazuzu Friend
What should I change in domain model example to see all available types in content assist when I about to define e.g entity property?
and second question. Statemachine example. I want to define state names as ID"::"ID, not as plain ID; how should I behave in such a case to see such names in content assist?
[Updated on: Sun, 03 July 2011 15:18]
Report message to a moderator
Re: xtext2 domainmodel example: no types in contentassist [message #692103 is a reply to message #692101] Sun, 03 July 2011 15:18 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
your first question i do not understand. what are you exactly doing and what is the problem. do you use a java project with Xtext nature added for the dmodel files?
to the second problem. Introduce a DataType Rule like
State:
	'state' name=SpecialId
		('actions' '{' actions+=[Command]+ '}')?
		transitions+=Transition*
	'end'
Transition:
	event=[Event] '=>' state=[State|SpecialId]
SpecialId: ID "::" ID;
Update: the missing IXtextBuilderParticipant should be no problem so far
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
[Updated on: Sun, 03 July 2011 15:25]
Re: xtext2 domainmodel example: no types in contentassist [message #692104 is a reply to message #692103] Sun, 03 July 2011 15:25 Go to previous messageGo to next message
You've answered so fast, it's amazing thanks
About first quesion. I install xtext2 domainmodel example and create foo.dmodel
package org.foo.bar{
	entity Foo {
		 foo : Foo
	entity Bar{
		bar: Bar
then I want to change type of property bar via content assist. Why no content assist appears after "bar :" on ctlr-space?
Re: xtext2 domainmodel example: no types in contentassist [message #692105 is a reply to message #692104] Sun, 03 July 2011 15:27 Go to previous messageGo to next message
is the dmodel within a java project with xtext nature added?
~Christian
Re: xtext2 domainmodel example: no types in contentassist [message #692106 is a reply to message #692105] Sun, 03 July 2011 15:35 Go to previous messageGo to next message
Oh, when I tried to create dmodel file in Java Project (in Eclipse launched from domain model example) i saw lot of exceptions like 'org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.OutOfMemoryError: PermGen space)'
Ok, any way, I don't need Java types. I need my own type system. Do you have an example of pure xtext2 DomainModel (without xtend, Java)?
Re: xtext2 domainmodel example: no types in contentassist [message #692107 is a reply to message #692106] Sun, 03 July 2011 15:42 Go to previous messageGo to next message
the easiest way is to take the one of Xtext 1.0.x
DomainModel:
	elements+=AbstractElement*;
AbstractElement:
	PackageDeclaration | Type | Import;
Import:
	'import' importedNamespace=QualifiedNameWithWildCard;
PackageDeclaration:
	'package' name=QualifiedName '{'
Type:
	Entity | DataType;
DataType:
	'datatype' name=ID;
Entity:
	'entity' name=ID ('extends' superType=[Entity|QualifiedName])? '{'
		features+=Feature*
Feature:
	StructuralFeature | Operation;
StructuralFeature:
	Attribute | Reference;
Attribute:
	name=ID ':' type=TypeRef;
Reference:
	'ref' name=ID ':' type=TypeRef ('opposite' opposite=[Reference])?;
Operation:
	visibility=Visibility? 'op' name=ID '(' (params+=Parameter (',' params+=Parameter)*)? ')' ':' type=TypeRef;
Parameter:
	name=ID type=TypeRef;
TypedElement:
	Feature | Parameter;
TypeRef:
	referenced=[Type|QualifiedName] multi?='*'?;
enum Visibility:
	public | private | protected;
QualifiedNameWithWildCard:
	QualifiedName '.*'?;
QualifiedName:
	ID ('.' ID)*;
~Christian
Re: xtext2 domainmodel example: no types in contentassist [message #692108 is a reply to message #692107] Sun, 03 July 2011 15:45 Go to previous messageGo to next message
Btw that no types are visible by default is a bug in my eyes. could you please file one into bugzilla.
~Christian
Re: xtext2 domainmodel example: no types in contentassist [message #692111 is a reply to message #692108] Sun, 03 July 2011 15:54 Go to previous message
Thanks, sure. https://bugs.eclipse.org/bugs/show_bug.cgi?id=351027
Previous Topic:Slot 'models' is empty
Next Topic:reference with spaces.
Current Time: Sun May 27 05:33:47 GMT 2018
Powered by FUDForum. Page generated in 0.02272 seconds
