Home » Newcomers » Newcomers » Matplotlib does not work in Eclipse(Matplotlib does not work in Eclipse)
Matplotlib does not work in Eclipse [message #691535] Fri, 01 July 2011 16:56 Go to next message
werner rolf is currently offline werner rolfFriend
I use Eclipse SDK, Version: 3.7.0 with PyDev 101.
Furthermore I have installed
- numpy-1.6.1rc1-win32-superpack-python2.6.exe
and
- matplotlib-1.0.1.win32-py2.6.exe
as noted here: matplotlib.sourceforge.net/users/installing.html
I have rebuild all the packages and looks the site-packages are listed.
(by the way as you see it is an Python version installed with ArcGIS )
If I test a script to check the installation like:
import numpy
arcpy.AddMessage("NUMPY Version " + numpy.__version__)
import matplotlib
arcpy.AddMessage("MATPLOTLIB Version " + matplotlib.__version__)
I get the following error:
NUMPY Version 1.6.1rc1
Traceback (most recent call last):
print "MATPLOTLIB Version " + matplotlib.__version__
AttributeError: 'module' object has no attribute '__version__'
Also the command
- import pylab as pl
import pylab as pl
from matplotlib.pylab import *
ImportError: No module named pylab
So even matplotlib is installed properly in the directory "site-packages" (see screenshot attached) it does not work in Eclipse.
Eclipse points properly as well (see 2nd screenshot attached). As you see I even added the directory matplotlib manually)
By the way if I let it run in iPython (same installation) it works perfect.
What still needs to be done to get matplotlib work in Eclipse?
Werner
Re: Matplotlib does not work in Eclipse [message #692022 is a reply to message #691535] Sun, 03 July 2011 07:43 Go to previous message
Michael Pellaton is currently offline Michael PellatonFriend
PyDev is not an Eclipse project. Chances of getting help for PyDev is
much higher in it's own support infrastructure [1].
[1] http://sourceforge.net/projects/pydev/forums/forum/293649
HTH
Michael
Previous Topic:Eclipse/AJDT Install Error
Next Topic:internal browser doesn't work
Current Time: Sun May 27 03:46:36 GMT 2018
Powered by FUDForum. Page generated in 0.02548 seconds
