Home » Eclipse Projects » BIRT » Report of a database schema
Report of a database schema [message #691431] Fri, 01 July 2011 08:50 Go to next message
Sascha Vogt is currently offline Sascha Vogt
I have a question regarding a report. Is it possible to generate
multiple tables in birt out of one dataset? Like for example I want to
display a whole database schema.
So the report should look like:
Report of <database>
<table1>
<col1-name> | <col1-datatype>
and the same for table2 and so on
Obviously I don't want to manually create a paragraph for each table in
the (unknown) database.
Greetings
-Sascha-
Re: Report of a database schema [message #691436 is a reply to message #691431] Fri, 01 July 2011 09:02 Go to previous messageGo to next message
Richard A. Polunsky is currently offline Richard A. Polunsky
Why do you want to create separate tables? You could just have one table and group by schema_tablename.
I suppose you could create separate tables on the fly but that would require a lot of java code.
Richard
Re: Report of a database schema [message #691450 is a reply to message #691436] Fri, 01 July 2011 09:25 Go to previous message
Hi Richard,
Am 01.07.2011 15:02, schrieb Richard A. Polunsky:
Because I would like to add text paragraphs in between. The database
schema example was just a simplified example. I have an unknown number
of "groups" in my original datasource and I have some "common"
information for each group which would need to be put in front of the
"details" table which is then the "rows" of the group entries.
Would it be possible to have sub-reports and a parametrized dataset to
achieve something like this (I'm a BIRT beginner, so I'm not sure what
features overall BIRT has to offer for particular problems. I don't even
know if there exist parametrized datasets and if there is a possiblity
to loop over a parameter list and execute sub-reports for each list entry).
Greetings
-Sascha-
Previous Topic:How to make the where clause optional on dataset SQL query??
Next Topic:Reports Not working while upgrading from Birt 2.6.1. to Birt 3.7
Current Time: Thu Jun 20 01:05:08 EDT 2013
Powered by FUDForum. Page generated in 0.25642 seconds
