Home » Eclipse Projects » Jubula » How would I create a new action for Swing combo box?(New Test Case, Swing Combo box)
How would I create a new action for Swing combo box? [message #691057] Thu, 30 June 2011 16:01 Go to next message
Francois Genolini is currently offline Francois GenoliniFriend
How could I create a new test case to check that the selected item in a Swing Combo box matches the text that I want to check?
I can see that there is:
unbound_modules_concrete_[5.0] | Actions (basic) | Check | Combo Box | ub_cbx_checkSelectionOfEntry_byIndex [INDEX; SELECTED]
I would like to create a new test case called:
ub_cbx_checkSelectionOfEntry_byValue [TEXT; OPERATOR]
When I try to edit a clone of ub_cbx_checkSelectionOfEntry_byIndex there is no choice in Action Type for "Check Selection of Entry by Value".
Would Check Text work for this?
Is it possible to add my own Action Type for Swing components?
Re: How would I create a new action for Swing combo box? [message #691079 is a reply to message #691057] Thu, 30 June 2011 16:33 Go to previous messageGo to next message
Achim Loerke is currently offline Achim LoerkeFriend
Well, "Check Text" on "Component with Text" should work but doesn't. We'll look into this.
Adding actions to components is currently supported for Swing, SWT and RCP/GEF. Sorry HTML testers, we're still working on this.
To define actions one actually has to write Java code and edit some XML files. You can find details in the Extension Information archive referenced on the Jubula Documentation page.
- Achim
Re: How would I create a new action for Swing combo box? [message #691265 is a reply to message #691079] Fri, 01 July 2011 06:25 Go to previous messageGo to next message
"Check text" of "Component with Text does work now.
I backtracked and tried again. No idea why it did not work first time round.
Re: How would I create a new action for Swing combo box? [message #691303 is a reply to message #691265] Fri, 01 July 2011 07:40 Go to previous message
I realized (while driving home yesterday) that I actually tested against an SWT application and in this context the "Check Text" didn't work. Obviously the Swing RC does things different.
- Achim
Previous Topic:Sync problems between forum and NNTP
Next Topic:How to start AUT agent with Eclipse Indigo and Jubula from the Market Place
Current Time: Sat Apr 21 21:34:26 GMT 2018
Powered by FUDForum. Page generated in 0.01590 seconds
