Home » Modeling » TMF (Xtext) » mismatched input
mismatched input [message #689754] Tue, 28 June 2011 09:41 Go to next message
Robin  is currently offline Robin Friend
I am a bit stuck while designing a grammar. Hopefully, someone can help.
This is my grammar so far:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	{Model}
	(tokens+=Token)*;
Token:
	'<TOKEN var1="' var1=ID '" var2="' var2=ID '">';
And this is an instance of the language:
<TOKEN var1="value1" var2="value2">
But I get the error: mismatched input '<EOF>' expecting '">'.
Why? It seems to me it is just consuming the '">' ??! Confused
Regards, Robin
Re: mismatched input [message #689769 is a reply to message #689754] Tue, 28 June 2011 10:14 Go to previous messageGo to next message
Alexander Nittka is currently offline Alexander NittkaFriend
your token rule does not look good. Why not use something like
Token:'<TOKEN' 'var1' '=' var1=STRING 'var2' '=' var2=STRING '>';
Whitespaces in tokens are not recommended and parsing within Strings ist not trivial.
Alex
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext@itemis.de
Re: mismatched input [message #689797 is a reply to message #689754] Tue, 28 June 2011 11:32 Go to previous messageGo to next message
Ah, that works! Thank you so much! Smile
So I guess, the parser just consumes everything that is not declared to be taken care of??
Regards, Robin
Re: mismatched input [message #689820 is a reply to message #689797] Tue, 28 June 2011 12:37 Go to previous messageGo to next message
before the parser does anything, the lexer chops up the input into tokens according to the definitions of terminals (and keywords) defined in your grammar (and the ones you inherit from). It is well possible that already the lexer does not produce the tokens you were expecting.
Alex
Re: mismatched input [message #689949 is a reply to message #689820] Tue, 28 June 2011 16:16 Go to previous message
Ahhhh, I see! Thanks for clearing that up!
Regards, Robin
Previous Topic:[xtext 2.0] importURI functionality totally messed up
Next Topic:Need some pointers setting up an xtext interpreter
Current Time: Wed Apr 25 07:12:28 GMT 2018
Powered by FUDForum. Page generated in 0.01874 seconds
