Home » Modeling » GMF (Graphical Modeling Framework) » Problem with setting routing example from wiki
Problem with setting routing example from wiki [message #689680] Tue, 28 June 2011 07:15 Go to next message
Ralph Gerbig is currently offline Ralph GerbigFriend
Hi all,
I found this example: http://wiki.eclipse.org/Graphical_Modeling_Framework/Tips#Setting_default_Routing_for_connections
This code causes a the following Exception:
IllegalStateException: Cannot activate read/write transaction in readonly transaction context.
Is there a way to fix this example?
Ralph
Re: Problem with setting routing example from wiki [message #689688 is a reply to message #689680] Tue, 28 June 2011 07:41 Go to previous message
I have this code as fix:
xxxFigure figure = new xxxFigure();
RoutingStyle style = (RoutingStyle)((View)getModel()).getStyle(NotationPackage.Literals.ROUTING_STYLE);
if (! (style.getRouting() == Routing.RECTILINEAR_LITERAL)){
  AbstractEMFOperation emfOp = new AbstractEMFOperation(getEditingDomain(), "routing") {
    protected IStatus doExecute(IProgressMonitor monitor, IAdaptable info) throws ExecutionException {
					style.setRouting(Routing.RECTILINEAR_LITERAL);
					return Status.OK_STATUS;
    try{
      OperationHistoryFactory.getOperationHistory().execute(emfOp, null, null);
    }catch(ExecutionException ex){
      ex.printStackTrace();
return figure;
What do you think?
Ralph
[Updated on: Tue, 28 June 2011 07:42]
Report message to a moderator
Previous Topic:Implementing views
Next Topic:Creating a view
Current Time: Fri May 25 16:51:28 GMT 2018
Powered by FUDForum. Page generated in 0.01698 seconds
