Home » Modeling » EMF » Wizard to create EMF model file(based on editor.xxx.presentation.yyyWizard )
Wizard to create EMF model file [message #687977] Thu, 23 June 2011 11:34 Go to next message
nicolas h is currently offline nicolas h
Member
Hi there,
I created an ecore model and a genmodel. Next, I generated "Model Code", "Edit Code" and "Editor Code".
The Editor plug-in generated proposes a wizard to create a new model file. I wish I created my own wizard based on the generated wizard.
Below is my own code :
WorkspaceModifyOperation op = new WorkspaceModifyOperation() {
protected void execute(IProgressMonitor monitor) throws CoreException,
			InvocationTargetException, InterruptedException {
// EditingDomain Creation if necessary
TransactionalEditingDomain editingDomain;
editingDomain = TransactionalEditingDomain.Registry.INSTANCE.getEditingDomain(SharedEditingDomainID);
if (editingDomain == null) {
	editingDomain = DiagramEditingDomainFactory.getInstance().createEditingDomain();
	editingDomain.setID(SharedEditingDomainID);
ResourceSet resourceSet = editingDomain.getResourceSet();
Resource resource = resourceSet.createResource(domainModelFileURI);
EObject rootObject = xxxFactory.eINSTANCE.createRootModel();
if (rootObject != null) {
	resource.getContents().add(rootObject); // It Doesn't work
// Save the contents of the resource to the file system.
Map<Object, Object> options = new HashMap<Object, Object>();
options.put(XMLResource.OPTION_ENCODING, "UTF8");
try {
	resource.save(options);
} catch (Exception e) {
	e.printStackTrace();
finally {
	monitor.done();
getContainer().run(false, false, op);
If I comment the line
, the file is well created, however, it doesn't contain any rootModel. If I don't comment the line, my application enter into an infinite loop (into org.eclipse.jface.window#runEventLoop(Shell))
Though, my code is very similar to the generated wizard, the only fundamental difference I think is how ResourceSet is instantiated. I tried to replace this line with
ResourceSet resourceSet = new ResourceSetImpl();
, it doesn't change anything.
Does anyone have an idea to solve this issue, please ?
Best regards
Nicolas
Re: Wizard to create EMF model file [message #688008 is a reply to message #687977] Thu, 23 June 2011 13:07 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Nicolas,
Comments below.
nicolas wrote:
> Hi there,
> @Override
> // EditingDomain Creation if necessary TransactionalEditingDomain
> editingDomain;
> editingDomain =
> editingDomain =
In what way doesn't it work. If you're using transactions, you need to
make modifications as part of a transaction. Is that the problem?
> try {
> finally {
> monitor.done();
> If I comment the line resource.getContents().add(rootObject);, the
Have you consulted with your best friend, the debugger?
> tried to replace this line with ResourceSet resourceSet = new
> ResourceSetImpl();, it doesn't change anything.
You've not made it clear yet why it's failing. Perhaps an exception is
being thrown? What type?
> Best regards
Re: Wizard to create EMF model file [message #688225 is a reply to message #688008] Fri, 24 June 2011 03:54 Go to previous messageGo to next message
Member
Hi, thanks for you reply.
You were right, an InvocationTargetException was thrown : "Cannot modify
resource set without a write transaction". I didn't have any error message since I didn't add the catch clause ...
I looked for a solution on the web by using transactionalEditingDomain. I found two ways, fist by using an AbstractTransactionalCommand, then by using RecordingCommand. None of them work.
My implementation of the two ways :
Using an AbstractTransactionalCommand :
	AbstractTransactionalCommand com = new AbstractTransactionalCommand(editingDomain, "shared editing domain", null) {
		protected CommandResult doExecuteWithResult(IProgressMonitor monitor,
						IAdaptable info) throws ExecutionException {
			return null;
	if (com.canExecute()) {
		try {
			OperationHistoryFactory.getOperationHistory().execute(com, new NullProgressMonitor(), null);
		} catch (ExecutionException e) {
org.eclipse.core.commands.ExecutionException: While executing the operation, an exception occurred
Caused by: java.lang.UnsupportedOperationException
Using RecordingCommand :
	TransactionalCommandStack stack = (TransactionalCommandStack) editingDomain.getCommandStack();
	stack.execute(new RecordingCommand(editingDomain) {
		protected void doExecute() {
java.lang.reflect.InvocationTargetException
Can you oriented me about the correct way to create my command please ?
Nicolas
Re: Wizard to create EMF model file [message #688398 is a reply to message #688225] Fri, 24 June 2011 11:44 Go to previous messageGo to next message
Nicolas,
Comments below.
That's what I expected, yes. The normal generated wizard doesn't use a
transactional editing domain. Is there a particular reason why you're
using one?
> them work.
> null) {
> @Override
> monitor,
> return null;
> try {
> Quote:
And you've used the debugger to figure out what's cause this? A stack
trace is always very helpful...
> @Override
> Quote:
No stack trace for this one either.
I'm not all that familiar with the transaction framework so I'm not sure
if you're using it correctly. I'm not sure why you're using it in a
wizard. It's not as if you're setting up the ability to undo the
creation of the resource...
> Best regards,
Re: Wizard to create EMF model file [message #692882 is a reply to message #688398] Tue, 05 July 2011 07:58 Go to previous messageGo to next message
Member
Hi Ed, sorry for the late.
What I want to do is the following steps :
1. Ask a project name to the user :
- I used a wizard for this;
- This wizard contains one field;
- Let's call the project name "projectName"
2. Create a project named "projectName" into the workspace :
public boolean performFinish() {
	root = ResourcesPlugin.getWorkspace().getRoot();
	IRunnableWithProgress op = new IRunnableWithProgress() {
	public void run(IProgressMonitor monitor) throws InvocationTargetException, InterruptedException {
		final IProject project = root.getProject(systemName);
		if (!project.exists()) {
			protected void execute(IProgressMonitor monitor) throws CoreException, InvocationTargetException, InterruptedException {
				project.create (new NullProgressMonitor());
				project.open (new NullProgressMonitor ());
		// Here, the code below to create and initialize a model file in step 3
	try {
		getContainer().run(false, true, op);
	} catch (InterruptedException e) {
		return false;
	} catch (InvocationTargetException e) {
		return false;
	return true;
3. Create a model file systemName.model into my project;
- My code is based on the code generated in the wizard in the plug-in Editor generated,
- I added a peace of code to automatically initialize my model file width some elements :
	resource.getContents().add(rootObject); // InvocationTargetException is thrown
	// I want to add some elements to my rootObject here
try {
finally {
	monitor.done();
4. I want to initialize automatically new diagram file from this model file.
An InvocationTargetException caused by an IllegalStateException is thrown : "Cannot modify resource set without a write transaction" when I tried to add my RootModel to my Resource :
I don't know why.
Do you have any idea to fix this ?
Nicolas
The stack trace below :
InvocationTarget
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:477)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:1008)
at org.test.wizard.NewHOE2ProjectWizard$1.run(NewProjectWizard.java:108)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
at org.test.wizard.NewProjectWizard.performFinish(NewProjectWizard.java:120)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:3783)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1375)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1398)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1383)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1195)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3629)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3284)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:254)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:274)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.test.Application.start(Application.java:84)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Caused by: java.lang.IllegalStateException: Cannot modify resource set without a write transaction
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting(TransactionChangeRecorder.java:348)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.appendNotification(TransactionChangeRecorder.java:302)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.processResourceNotification(TransactionChangeRecorder.java:272)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.notifyChanged(TransactionChangeRecorder.java:238)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:380)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.dispatchNotification(NotifyingListImpl.java:267)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:300)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:307)
at requirements.diagram.part.CreationNewDiagram$1.execute(CreationNewDiagram.java:63)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1975)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
at requirements.diagram.part.CreationNewDiagram.execute(CreationNewDiagram.java:67)
... 61 more
Re: Wizard to create EMF model file [message #692974 is a reply to message #692882] Tue, 05 July 2011 11:06 Go to previous messageGo to next message
Comments below.
You're expecting to be able to undo project creation?
> @Override
> @Override
> in step 3
> try {
> return false;
> return false;
> return true;
> Editor generated,
> @Override
> editingDomain;
> editingDomain =
> editingDomain =
> try {
> finally {
> monitor.done();
This strikes me as another thing that can't be undone.
> file.
> I don't know why.
Again, I have to wonder why you're using commands at all. None of this
strikes me as stuff that needs to be undone.
Re: Wizard to create EMF model file [message #693266 is a reply to message #692974] Wed, 06 July 2011 02:56 Go to previous messageGo to next message
Member
That's a good point, I don't need to use commands since I don't want to undone these actions.
If I tried to use AbstractTransactionalCommand or RecordingCommand, It's only because I found these class as a solution to solve the "Cannot modify resource set without a write transaction" issue.
Regarding the WorkspaceModifyOperation class, if I don't get its purpose wrong, we have to use it when the code makes changes to the workspace (project, folder, file, generally Resource creation into the workspace) right ?
Nicolas
[Updated on: Wed, 06 July 2011 02:57]
Report message to a moderator
Re: Wizard to create EMF model file [message #693287 is a reply to message #693266] Wed, 06 July 2011 03:44 Go to previous messageGo to next message
Yes, you should modify the workspace as part of an operation that groups
all the related changes into a single workspace delta.
> workspace) right ?
Re: Wizard to create EMF model file [message #693324 is a reply to message #693287] Wed, 06 July 2011 05:12 Go to previous message
Member
I found where my error is located :
I can't write into this resourceSet.
If I replace this by
It works. However, I'm pretty sure that I've already try this and it didn't work ...
Well, it works now, but it seems like I don't know how to use editing domains yet ...
Thanks for you help Ed Wink I've a lot of things to learn ...
Nicolas
Previous Topic:Code Generation Programatically
Next Topic:[CDO] Migrating to RC2 - driver not found
Current Time: Wed Jun 19 03:27:52 EDT 2013
Powered by FUDForum. Page generated in 0.01938 seconds
