Home » Modeling » EMF » (no subject)
(no subject) [message #687432] Fri, 10 June 2011 00:09
Steve Robenalt is currently offline Steve RobenaltFriend
Hi Stefan,
You can package a CDO Server in a war layout very similar to the one used by RAP. There's one small change needed to the RAP framework's launcher in order to coerce it to start the CDO Server application. I'm still testing it to determine if there are side effects to the launcher modification, but so far, so good. I'm working on a howto document for the war configuration - hopefully to get it on the CDO wiki soon.
Alternately, you can export the CDO product in a manner similar to an RCP application and launch it when the server starts up.
The advantage to the war packaging is that it will run in any application server since it doesn't require a platform specific launcher. Also, it should work fine in a cloud environment.
Steve Robenalt
Previous Topic:CDO Server Deployment
Next Topic:Databinding on DateTime widget
Current Time: Sat Apr 21 04:35:44 GMT 2018
Powered by FUDForum. Page generated in 0.02289 seconds
