Home » Archived » Maven Integration (M2E) » Prevent downloading repository index updates on startup
Prevent downloading repository index updates on startup [message #686437] Wed, 22 June 2011 08:50 Go to next message
Christian Dietrich is currently offline Christian DietrichFriend
is there a possibility to do
what can be done with unchecking "download repository index updates on startup" in the preferences with a (-D....=false) parameter on the startup of eclipse?
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
[Updated on: Wed, 22 June 2011 09:21]
Report message to a moderator
Re: Prevent downloading repository index updates on startup [message #689880 is a reply to message #686437] Tue, 28 June 2011 14:32 Go to previous messageGo to next message
Ger  is currently offline Ger Friend
You have this option into the properties of maven. Go to Window-Preferences-Maven and there you'll find an option "Download repository index updates on startup". Just uncheck it.
Re: Prevent downloading repository index updates on startup [message #690046 is a reply to message #689880] Tue, 28 June 2011 21:23 Go to previous message
Hi, i ve already Seen this Option but i am searching for an Option to switch this off from outside since the refresh happen when i run junit Plugin tests. ~christian
Previous Topic:Correct update site?
Next Topic:problem using Checkout as Maven project from SCM Window
Current Time: Thu May 24 14:14:24 GMT 2018
Powered by FUDForum. Page generated in 0.01886 seconds
