Home » Language IDEs » ServerTools (WTP) » "Real time" content assist(How does it work?)
"Real time" content assist [message #685966] Tue, 21 June 2011 06:53 Go to next message
MarcoGT  is currently offline MarcoGT Friend
Member
I am going on with my work on content assist with proposals taken from external xml file.
One question: default content assist re-computes proposals every time the "match string" is modified and the box is filled with new proposals.
At the moment my content assist must be recalled (CTLR+Space bar) every time the "match string" is modified.
How to do it as the default one?
My content assist at the moment makes an XPath query every time you call it (with CTRL+Space bar) but probably the best solution is to load all the result at the beginning and then filter them during typing...isn't it?
Which is the class responsible that does this task?
I think it is not inside org.eclipse.wst.xml.ui...
Marco
[Updated on: Tue, 21 June 2011 13:00]
Report message to a moderator
Re: "Real time" content assist [message #686097 is a reply to message #685966] Tue, 21 June 2011 17:18 Go to previous messageGo to next message
Nick Sandonato is currently offline Nick SandonatoFriend
Hi Marco,
Do you have your own ICompletionProposal? Most often when I've seen this problem is when ICompletionProposalExtension2 is not implemented or ICompletionProposalExtension2#validate() is implemented incorrectly.
[Updated on: Tue, 21 June 2011 17:18]
Re: "Real time" content assist [message #686362 is a reply to message #686097] Wed, 22 June 2011 05:18 Go to previous message
Member
I have implemented my content assist as suggested here using "CustomCompletionProposal" and then "contentAssistRequest.addProposal(CustomCompletionProposal).
Another thing that I have seen is:
if I write "t" and then press CTRL+Space content assist ok, then I write "test" and to get the proposals I have to recall the content assist again...but if I start to delete "test" the content assist is recalled automatically for every deleted char.
Marco
Previous Topic:WTP server adapter - new extension points for UI modification
Next Topic:StructuredDocument - requesting re-parse?
Current Time: Sun Feb 18 07:29:42 GMT 2018
Powered by FUDForum. Page generated in 0.01262 seconds
