Home » Eclipse Projects » BIRT » use jndi with connection profile ?(I need a way to be independant of target DB)
use jndi with connection profile ? [message #684521] Wed, 15 June 2011 18:02 Go to next message
Cyril Rognon is currently offline Cyril RognonFriend
Hello all,
I am using Birt with connection profile. On the design time, everything works really fine. Very Happy
Then my design is under windows and I deploy to linux.
troubles begin when I want to use my connection profile : it encloses a jarlist property that is tied to my design environement. The driver is not found even if it is in the lib directory of tomcat.
On design I use a jdbc/profile connection.
On my target Tomcat system ther is a jndi datasource. How can I use this ?
Could I use a connection profile on design environement and a jndi DS on the target environement ?
Cyril
(no subject) [message #684553 is a reply to message #684521] Wed, 15 June 2011 19:25 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
You can change the connection profile dynamically either through
property binding or script. For example say you put a connection
profile in the resource folder of your deployment. You could add a
beforeOpen script to set the connection profile like:
if(
!reportContext.getHttpServletRequest().getAttribute("attributeBean").isDesigner()
myresourcefolder = reportContext.getDesignHandle().getResourceFolder()
this.setExtensionProperty("OdaConnProfileStorePath",
myresourcefolder+"/mysqlclassic.txt");
On 6/15/2011 2:02 PM, Cyril Rognon wrote:
> Hello all,
> works really fine. :d
> Thanks
> Cyril
icon14.gif  Re: (no subject) [message #684754 is a reply to message #684553] Thu, 16 June 2011 07:27 Go to previous messageGo to next message
Hello jason,
thx for your quick answer as always.
I did use another trick that is close to your solution : the connection profile store URL property bindind.
there I have this expression : reportContext.getAppContext().get("birt.viewer.resource.path") +"/mypath/mydb.store"
do you think before open might be a better place ?
this way I have mydb.store file on dev and production that are different.
now I am looking for documentation in order to use a jndi datasource in a connection profile... when I use birt/dtp tools it seems I cannot provide a sole jndi name. it requires db url, drivers, etc...
Can anyone point me to a valuable ressource on this matter ?
regards
Cyril
Re: (no subject) [message #684926 is a reply to message #684754] Thu, 16 June 2011 13:37 Go to previous message
That is fine. On jndi I believe that dburl, etc are used only if the
jndi connection fails.
Jason
On 6/16/2011 3:27 AM, Cyril Rognon wrote:
> Hello jason,
> regards
> Cyril
Previous Topic:Use output of a dataset into another dataset
Next Topic:(no subject)
Current Time: Mon May 21 11:17:40 GMT 2018
Powered by FUDForum. Page generated in 0.02355 seconds
