Eclipse Marketplace
Eclipse YouTube Channel
Bugzilla
Eclipse Forums
Planet Eclipse
Eclipse Wiki
My Foundation Portal
Downloads
Users
Members
Committers
Resources
Projects
About Us
Search
Help
Register
Login
Modeling
TMF (Xtext)
[Xtend2] Difference between val and var ?
Show:
Today's Messages
Show Polls
Message Navigator
message #684471
Wed, 15 June 2011 12:11
Jos Warmer
104
October 2010
Within an Xtend class I can use var and val keywords to define variables. E.g.
val String s1 var String s2
What is the difference between val and var ?
Report message to a moderator
Re: [Xtend2] Difference between val and var ?
message #684475
is a reply to
message #684471
Wed, 15 June 2011 12:15
Christian Dietrich
4419
July 2009
vals are what final is in java.
Xtend <=> Java
val String s1 <=> final String s1 = null
var String s2 <=> String s2
~Christian
message #684496
is a reply to
message #684475
Wed, 15 June 2011 12:58
Jos Warmer
104
October 2010
Christian,
Thanks, that is clear. I could not find it in the documentation. Either I did not look good enough, or otherwise it might be good to add this.
jos
message #684530
is a reply to
message #684496
Wed, 15 June 2011 14:39
Christian Dietrich
4419
July 2009
just for completeness: You find it in the Xtend Docs Section Expressions -> Variable Declarations
~Christian
[Updated on: Wed, 15 June 2011 14:39]
message #684587
is a reply to
message #684530
Wed, 15 June 2011 17:26
Jos Warmer
104
October 2010
Christian,
thanks, you are right.
I should learn to read better
jos
Previous Topic:
EObject from global scope has less information
Next Topic:
[Xtext 2.0] Bug in PreferenceStoreAccessImpl?
- Newcomers
Newcomers
- Language IDEs
AJDT
COBOL
CDT
Java Development Tools (JDT)
PDT
Objectteams
- Modeling
AMP
Amalgam
AMW
B3
ATL
BPEL Designer
Compare
Ecore Tools
EMF
EMF Client
EMF Store
EMF "Technology" (Ecore Tools, EMFatic, etc)
Epsilon
eTrice
Extended Editing Framework (READ ONLY)
Eclipse Generation Factories (EGF)
GMF (Graphical Modeling Framework)
GMT (Generative Modeling Technologies)
Graphiti
M2T (model-to-text transformation)
MDT (Model Development Tools)
Modeling (top-level project)
OCL
Papyrus
TMF (Xtext)
UML2
UML2 Tools
XSD
MoDisco
MOFScript
Presentation Modeling Framework (PMF)
Sphinx
Textual Concrete Syntax (TCS)
UMLX
VIATRA2
Model-to-Model Transformation
QVT-OML
QVT-Relations
EMF Diff/Merge
- Eclipse Projects
ACTF
Apricot
ATF
Babel
BIRT
Blinki
BPMN 2.0 Modeler
Buckminster
Buckminster dev
C-Sharp
Code Recommenders
Commercial
Dali
Dash
DSDP
DSDP - Device Debugging
DSDP - Mobile Tools for Java (MTJ)
DSDP - Real-Time Software Components (RTSC)
DSDP - Target Management
DSDP - Tools for Mobile Linux (TML)
DTP
Dynamic Languages Toolkit (DLTK)
e(fx)clipse
eBAM
eBPM
Eclipse 4
Eclipse Bundle Recipes
Eclipse Communications Framework (ECF)
Eclipse Examples
Eclipse Platform
Eclipse Process Manager (Stardust)
Eclipse RT (runtime)
Eclipse Technology Project
Eclipse UML Profiles Repository
Eclipse Website
EclipseLink
EGit
EGL Development Tools
EMF-IncQuery
EPF
EPP
Equinox
eRCP
g-Eclipse
GEF
GEF3D
Gemini
GEMS
Gyrex
Higgins
Hudson
IDE4EDU
IMP
Java Workflow Tooling
Java WorkFlow Tooling (JWT)
JavaServer Faces
JFace
Jubula
Koneki
Libra
Linux Tools Project
Lyo
Mangrove
Marketplace Client Project
Maven Integration (M2E)
Memory Analyzer
Model Focusing Tools
MST
Mylyn
Mylyn Builds
Mylyn Intent
Mylyn Versions
NatTable
Nebula
OMCW
Orbit
Orion
OSEE
P2
Paho
Platform - User Assistance (UA)
Plugin Development Environment (PDE)
Remote Application Platform (RAP)
Remus Information Management
Requirements Modeling Framework
Rich Client Platform (RCP)
Riena
Runtime Analysis Tools
Runtime Packaging
Runtimes
Sapphire
scout
SeMantic Information Logistics Architecture (SMILA)
Sequoyah
Service Component Architecture (SCA) Tools
Service Oriented Architecture
Service Oriented Architecture Tools Platform (STP)
Silverlight Development Toolkit (SLDT)
Simultaneous release
Sisu
Skalli
Sketch
Spatiotemporal Epidemiological Modeler (STEM)
Standard Widget Toolkit (SWT)
Subversive
Swordfish
SWTBot
Target Communication Framework
Target Management
Technology Project and PMC
Test and Performance Tools Platform (TPTP)
Tigerstripe
Turkish Users
UOMo
Vex
Virgo
VJet
Voicetools
Wazaabi
Web Tools Project (WTP)
Webtools incubator
WindowBuilder
Woolsey
WTP - PAVE
XML Schema Definition (XSD)
Xtend
XWT
- General (non-technical)
Board committer reps
Polish users
Eclipse Foundation
Jobs and employment
Proposals
EclipseCon
Test
- Eclipse Working Groups
Pulsar
Automotive IWG
- Proposals
Potomac
secRT
OSGi Enterprise Tools
- Archived
Albireo
AM3
openArchitectureWare
BPMN Modeler
Apogee
Corona
Hibachi
Glimmer
Maynstall
DSDP - Native Application Builder (NAB)
ORMF
Spaces
ScalaModules
Visual Editor (VE)
P2 dev
Cloud Deployment Toolkit
Memory Analyzer (MAT)
COSMOS
Esl
OFMP
Faceted Project Framework
IAM (Eclipse Integration for Apache Maven)
M2M (model-to-model transformation)
OHF
Tycho
Back to Top
Syndicate this forum (XML)
Current Time:
Thu May 23 06:05:16 EDT 2013
FUDForum
. Page generated in 0.01647 seconds
