Home » Modeling » GMF (Graphical Modeling Framework) » GMF Databaseconnection Issue(hibernate/postgres/mindmapexample)
GMF Databaseconnection Issue [message #684427] Wed, 15 June 2011 14:54 Go to next message
Andreas  is currently offline Andreas Friend
i want to store/load all GMF-diagram and modelcontent into a postgressql-database.
To learn how it could be done, i`m trying the hibernate/teneo/gmf-example (mindmap) with changes to use postgres-DB.
I´m able to store and load the node-element ("Topic"). At this point i`m able to close and reopen editor without failure.
When i connect two nodes with a connection-element ("Subtopic"), safe, close and reopen the editor, the editor remains "dirty".
Trying to safe in this state causes
"Save Failed
object references an unsaved transient instance - save the transient instance before flushing: Edge"
"org.hibernate.ObjectDeletedException: deleted object would be re-saved by cascade (remove deleted object from associations)"
I read a lot and tried a lot of different settings in hibernate.hbm.xml especially different cascade-settings but nothing works.
Maybe someone knows the answer.
With kind regards
Re: GMF Databaseconnection Issue [message #684450 is a reply to message #684427] Wed, 15 June 2011 15:31 Go to previous messageGo to next message
Joao S is currently offline Joao SFriend
Member
I don´t really know the answer but I´m having the exactly same issue.
Somehow I think that this is a Reference Based Links specific issue.
When you do this:
Are you able to delete the subtopic link?
Best Regards,
João
Re: GMF Databaseconnection Issue [message #684749 is a reply to message #684450] Thu, 16 June 2011 07:09 Go to previous messageGo to next message
Hello João,
>> Are you able to delete the subtopic link? <<
No, i`m not. It`s possible to delete the link from diagram but trying to save this causes the same error message/exception as described above.
I`m glad i`m not the only one with this issue Smile
with kind regards
Andreas
Re: GMF Databaseconnection Issue [message #686465 is a reply to message #684749] Wed, 22 June 2011 09:32 Go to previous message
I solved this issue.
that`s my way:
1. I stripped down the mindmap.ecore to the basic elements(see ecore file attatched)
2. I changed properties of the "target"-association (Relationship-Topic)
Derived == true
3. StoreController was changed from "localDataStore.setProperties(props);" to
"localDataStore.setDataStoreProperties(props);"
Honestly, i`m not sure what exactly solved the issue. My favourites are Point 1 and 2 Smile
with kind regards
Andreas
Previous Topic:Enabling drag-n-drop from palette
Next Topic:Add and Delete a Compartment Dynamically
Current Time: Thu Apr 26 19:30:01 GMT 2018
Powered by FUDForum. Page generated in 0.01938 seconds
