Home » Eclipse Projects » BIRT » Newbie: web viewer report - html set left margin(How to set left margin of a report shown via webviewer)
Newbie: web viewer report - html set left margin [message #684285] Wed, 15 June 2011 11:03 Go to next message
endiBirt  is currently offline endiBirt Friend
Hi all,
does anybody know what is the easiest way to set the left margin of a report when viewed via webviewer.
Is it the Masterpage - Margin - Setting? Seems not, perhabs only for pdf or doc...
Or is it possible to adjust it via script?
Or should it be done via css?
Thanks for any hint in advance.
Andreas
Re: Newbie: web viewer report - html set left margin [message #684396 is a reply to message #684285] Wed, 15 June 2011 14:26 Go to previous messageGo to next message
Ha ok, found it. Sorry, realy stupid. Styles is the magic word.
The only problem I now cannot solve is how to set a style via script. For instance if you have a lableHandle there isnt a setStyle method.
How can I set a style to an element via script?
Andreas
Re: Newbie: web viewer report - html set left margin [message #684438 is a reply to message #684396] Wed, 15 June 2011 14:45 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
The easiest way is to name the label in the general properties and in
the beforeFactory script do something like:
reportContext.getDesignHandle().findElement("mylabel").setStyleName("highlight-orange");
Jason
> Regards
> Andreas
Re: Newbie: web viewer report - html set left margin [message #684767 is a reply to message #684438] Thu, 16 June 2011 08:01 Go to previous messageGo to next message
Hi Jason,
thank you very much for the hint. It worked like a charm.
Please let me ask one last question. I made a new style, set Box - Margin left 20 points. The style works for labels but fails when set to a grid. The grid ignores the style. I don't see a reason, why.
Reagards
Andreas
PS: Yes, I should have opened a new Thread. Please sorry...
Re: Newbie: web viewer report - html set left margin [message #684769 is a reply to message #684767] Thu, 16 June 2011 08:04 Go to previous message
Ah found it. The grid has a separate Margin Set Possibility.
Thanks again.
Andreas
Previous Topic:Using Array data in graphs
Next Topic:SLF4J Support
Current Time: Tue Jan 16 10:02:23 GMT 2018
Powered by FUDForum. Page generated in 0.02381 seconds
