Home » Language IDEs » C / C++ IDE (CDT) » Setting breakpoint to running program and other bugs???(A series of bugs (???).)
Setting breakpoint to running program and other bugs??? [message #684250] Wed, 15 June 2011 09:46 Go to next message
Marko Mikkonen is currently offline Marko MikkonenFriend
I can't set breakpoints to a running program. I can set them before I start debugging or when the program stops at some breakpoint, but not during running the program. This is the most annoying of CDT bugs I've found.
My projects are Qt and regular static library C++ projects. My CDT version is 7.0.1. I tried to install 7.0.2 but couldn't. The installer said that packages were already installed, so it would perform an update instead but wouldn't let me click the finish button. So the installer is also broken.
Also other bugs: I have a static library and other projects depend on it (Qt projects). When I make changes to the static library and try to build another project that depends on it, the static library is built, but the other project is not relinked.
I also consider this as a bug (but maybe there's a fix for it that I just haven't found?). In Eclipse help window the default font is too small to read. The letters are like 1mm high. I simply can't read them. Is there a way to make them bigger? I tried fiddling with window->preferences->appearance->colors and fonts but couldn't find a setting that would change the font in help window.
Edit: My OS is Windows 7.
[Updated on: Wed, 15 June 2011 12:09]
Report message to a moderator
Re: Setting breakpoint to running program and other bugs??? [message #684422 is a reply to message #684250] Wed, 15 June 2011 14:52 Go to previous messageGo to next message
Doug Schaefer is currently offline Doug SchaeferFriend
Feel free to enter bugs here: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=CDT
Re: Setting breakpoint to running program and other bugs??? [message #684449 is a reply to message #684422] Wed, 15 June 2011 15:30 Go to previous message
I filed a bug about the broken installer and relinking problem. They are the bugs 349414 and 348887. Feel free to vote them!
There was already a bug about setting the breakpoints (bug 346584). So I voted that. Someone got interested in it. That's a positive thing.
Previous Topic:Switch-Case Template (Surround with...)
Next Topic:How to call existing C functions in executable file during debug session?
Current Time: Thu Apr 26 13:53:30 GMT 2018
Powered by FUDForum. Page generated in 0.02143 seconds
