Home » Eclipse Projects » EclipseLink » Translating PersistenceException to DataAccessException with EclipseLinkJpaDialect
Translating PersistenceException to DataAccessException with EclipseLinkJpaDialect [message #683717] Tue, 14 June 2011 09:45 Go to next message
Massimo Ugues is currently offline Massimo UguesFriend
Hallo all.
I use EclipseLink as JPA vendor and I have a problem with the EclipseLinkJpaDialect.
I notice that extends DefaultJpaDialect but not overrides the translateExceptionIfPossible method.
So in my test case I have a unique constraint violation exception and debugging the control flow shows this stacktrace:
EntityManagerFactoryUtils.convertJpaAccessExceptionIfPossible(RuntimeException) line: 282
EclipseLinkJpaDialect(DefaultJpaDialect).translateExceptionIfPossible(RuntimeException) line: 120
LocalContainerEntityManagerFactoryBean(AbstractEntityManagerFactoryBean).translateExceptionIfPossible(RuntimeException) line: 368
ChainedPersistenceExceptionTranslator.translateExceptionIfPossible(RuntimeException) line: 58
DataAccessUtils.translateIfNecessary(RuntimeException, PersistenceExceptionTranslator) line: 213
PersistenceExceptionTranslationInterceptor.invoke(MethodInvocation) line: 163
ReflectiveMethodInvocation.proceed() line: 172
The exception of the call is:
javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.1.2.v20101206-r8635): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: [BEA][Oracle JDBC Driver][Oracle]ORA-00001: unique constraint (JSP_OWN.IDX_MC_CC_RAPPORTI_02) violated
The final exception that is returned is the general JpaSystemException:
org.springframework.orm.jpa.JpaSystemException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.1.2.v20101206-r8635): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLIntegrityConstraintViolationException: ORA-00001: violata restrizione di unicità (CONT_OWN.PK_CONT_EVENT_MESSAGE)
Any idea how to get the machine works for EclipseLink? Kind regards
Massimo
Re: Translating PersistenceException to DataAccessException with EclipseLinkJpaDialect [message #692449 is a reply to message #683717] Mon, 04 July 2011 13:04 Go to previous message
jj Missing name is currently offline jj Missing nameFriend
Hi, I'm working on the same issue - I suspect its all working as designed, the code is using the EclipseLinkJpaDialect & is being processed by the translateExceptionIfPossible() method. The real problem is there is not a 'standard' persistence api subclass of PersistenceException that matches to the concept of a unique-constraint-exception. That being the case the translation falls through, skipping EntityExistsException, EntityNotFoundException etc.. to the generic PersistenceException.
The problem now seems how to move forward. Either start adding in custom mapping for the entity saves (where my exceptions are primarily generated) that pick up the constraint violation or apply a updated advice - I suppose it comes down to best practice. Any thoughts?
(no subject) [message #692452 is a reply to message #683717] Mon, 04 July 2011 13:04 Go to previous message
Previous Topic:(no subject)
Next Topic:derived identifier of derived identifier
Current Time: Sun Feb 25 23:59:13 GMT 2018
Powered by FUDForum. Page generated in 0.02037 seconds
