Home » Modeling » M2T (model-to-text transformation) » XPand UML Version
XPand UML Version [message #682556] Sat, 11 June 2011 12:37 Go to next message
st oehm is currently offline st oehmFriend
Member
hi to all
does anybody know which UML-Version XPand is using
i mean the predefined UML Version which you can select in the XPand Project wizzard
thanks for help
best regards
stoehm
[Updated on: Sat, 11 June 2011 12:39]
Report message to a moderator
Re: XPand UML Version [message #682560 is a reply to message #682556] Sat, 11 June 2011 12:53 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
i am not sure what your questions is targeting, but it uses the Eclipe UML2 org.eclipse.uml2.uml.UMLPackage you hopefiully have installed in your eclipse.
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
[Updated on: Sat, 11 June 2011 13:09]
Re: XPand UML Version [message #683698 is a reply to message #682560] Tue, 14 June 2011 09:11 Go to previous message
Member
hi christian,
thanks for you reply.
what i want to know which UML-version is actually supported. since march there is the UML 2.4 beta out, which some modifications, i cant use in my templates (but i'd like to)
maybe then this is a question for the uml forum
best regards
stoehm
Previous Topic:[ACCELEO] module UML 2.1 To PHP in acceleo 3.0
Next Topic:Xpand: avoid duplicates?
Current Time: Wed May 23 07:03:55 GMT 2018
Powered by FUDForum. Page generated in 0.02273 seconds
