Home » Modeling » TMF (Xtext) » Problem generating in Xtext 2.0
Problem generating in Xtext 2.0 [message #677183] Tue, 07 June 2011 19:28 Go to next message
Mary Komor is currently offline Mary KomorFriend
Member
I installed Eclipse 3.7 RC3 + Xtext 2.0 and am getting the error below when
I try to generate using my mwe2 file. I am able to generate using the
DomainModel example. I was able to generate using Eclipse 3.6.2 + Xtext
1.0.2 using the same mwe2 file.
Am I missing something?
4 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Nullparser
java.lang.UnsupportedOperationException: Nullparser
org.eclipse.xtext.parser.antlr.IAntlrParser$NullParser.parse(IAntlrParser.java:39)
at org.eclipse.xtext.resource.XtextResource.doLoad(XtextResource.java:146)
org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLoad(LazyLinkingResource.java:63)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1511)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1290)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getResource(SynchronizedXtextResourceSet.java:23)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:47)
org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Re: Problem generating in Xtext 2.0 [message #677209 is a reply to message #677183] Tue, 07 June 2011 20:31 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
it seems you still have some Xtext 1.0.x stuff installed or on classpath. please make sure that your workflows project has deps to the Xtext 2.0.0 plugins. see Migrating from Xtext 1.0.x to 2.0 from the docs
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
[Updated on: Tue, 07 June 2011 20:33]
Report message to a moderator
Re: Problem generating in Xtext 2.0 [message #677241 is a reply to message #677183] Tue, 07 June 2011 22:04 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Mary,
Xtext 2.0 requires Antlr 3.2. Please make sure that the parser generator
is available in exactly that version. The easiest way would be to
install Xtext from http://download.itemis.com/updates/milestones
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 07.06.11 21:28, schrieb Mary Komor:
> when I try to generate using my mwe2 file. I am able to generate using
> the DomainModel example. I was able to generate using Eclipse 3.6.2 +
> Xtext 1.0.2 using the same mwe2 file.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problem generating in Xtext 2.0 [message #677268 is a reply to message #677241] Wed, 08 June 2011 00:04 Go to previous message
Member
I think this *may* have been due to an incorrect setup in my Target
Platform. It's working now. Thanks for your help!
Mary
"Sebastian Zarnekow" <Sebastian.Zarnekow@itemis.de> wrote in message
news:ism6jh$6cf$1@news.eclipse.org...
> Hi Mary,
> is available in exactly that version. The easiest way would be to install
> Sebastian
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:navigating through an importURI statement
Next Topic:learning xtext
Current Time: Fri May 25 11:16:21 GMT 2018
Powered by FUDForum. Page generated in 0.01476 seconds
